Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-11-2013, 12:58 AM   #1
low&slow
Anyone Running 26x11.50-15 tires??
Just as the title asks. Post pics if you are or have a picture with that size rear tire.
Found a pair of MT ET Streets on the local CL and might get them. Not sure though. I'm thinking they may be a bit too short at 26" tall, but if I get them I will be putting them on 15x10 rims. Just want to get an idea of what they look like mounted on a truck.
low&slow is offline   Reply With Quote
Old 10-11-2013, 12:47 PM   #2
Super73
Super73's Avatar
Re: Anyone Running 26x11.50-15 tires??
Having run ET Streets and also running ET Street radialls, I strongly urge you to go the rdial route. They just work better.
I have run 28x11.50 et streets on my now sold 2001 camaro.
Also run Nitto 555r radials on the Camaro and they worked as good as the ET Street. They are not known to be the best radial.
On the truck i have run:
275/50/15 bfg radials
30x13.50 et streets
315/60/15 et street radials.
So far et street radial is my favorite.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-13-2013, 05:02 PM   #3
low&slow
Thanks for the advice. I'll have to look for a pair of radials.
I'm trying to find a tire that fills the fender in the rear of my 69 c10. I'm thinking a 26" tire won't do that very well. I've been leaning more towards a 30" tall tire, but seems I can't find any of those on CL.
Old 10-14-2013, 05:40 PM   #4
C0UCH
I'm running 325/50R15 on 15x9.5 w/4.5" BS Aero wheels. All four are the same size/offset. The tires are Nitto 555R tires. At right around 28" tall, they fill the wells pretty well. Currently sitting on 3/5 springs.
C0UCH is offline   Reply With Quote
Old 10-14-2013, 06:49 PM   #5
Super73
Super73's Avatar
Couch.. was wondering if you were still around..
Old 10-14-2013, 07:17 PM   #6
low&slow
Thanks for the pics. I think 26" will be alright for now. If you don't mind me asking, how much were the tires you bought for it?
Old 10-14-2013, 09:09 PM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
Not a bad tire , i have a set of 26 x 10.5 x 16 s for my work truck
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-15-2013, 11:17 PM   #8
C0UCH
Yeah, I'm still around. Just haven't had much time lately for the truck.
The tires are usually around 200 a piece. These were 250 from Diamondback Tires after their "Smoothie" treatment on the sidewalls. I wanted a blank canvas for the Goodyear logos.
Old 10-17-2013, 03:27 PM   #9
low&slow
The tires I may be getting are kinda basically just a trial tire. I won't actually be ran at the track nor on the street. Just trying to figure out sidewall height. I'm looking for an aggressive side wall. Almost pro-street look. I've seen pics on google, they look good on cars, but not sure about a 69 c10
Old 10-17-2013, 06:43 PM   #10
C0UCH
I figured out mine by buying some used NASCAR Goodyear Eagles and mounting them to the Aero wheels I wanted. Test fit, spun them around the block a bit then ordered the closest size tire I could find.
Old 10-17-2013, 10:13 PM   #11
low&slow
I may just have to do that as well.
Old 03-19-2014, 12:20 AM   #12
01wr426
Couch, I like the look of your truck. I have been contemplating buying Aero 59's as well, but don't want them to rub the front wheel wells or stick out past the fenders. My ride height is just a tad lower than yours, have you had any issues? Also are you running CPP SOS spindles or is that the stock track width?
01wr426 is offline   Reply With Quote
