Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-17-2013, 08:15 PM   #1
crazyhenryj
65 Suburban Quarter Panel Patches
I have on the list to cut and swap the passenger rear quarter panel on my 65 it had a nasty something back in the day and I think pulling pounding and smoothing with minimal filler is out of the question for this guy. Which sucks because it has great patina'd paint. Here are a couple pics of the damage.
Does anyone make replacement parts or have a line on cut up pieces?
Thanks HaNK
crazyhenryj is offline   Reply With Quote
Old 10-17-2013, 10:25 PM   #2
63burban
Chevy addict
Re: 65 Suburban Quarter Panel Patches
A good body man can straighten that out. It's a clean Suburban otherwise, why cut it up, spend a couple bucks on a body man. the damage isn't real bad.
63burban is offline   Reply With Quote
Old 10-17-2013, 10:59 PM   #3
perro13
perro13's Avatar
x2
perro13 is offline   Reply With Quote
Old 10-17-2013, 11:34 PM   #4
oem4me
That's fixable. No need to Frankenstein that OG panel.
Old 10-17-2013, 11:42 PM   #5
padresag
note that 63burban said a good bodyman.
ron
padresag is offline   Reply With Quote
Old 10-18-2013, 12:38 AM   #6
Captainfab
60-66 Nut
I agree with trying to find a 'good' body man, one that knows how to work metal.
Old 10-18-2013, 03:14 AM   #7
crazyhenryj
Good body man good idea Weld a pull plate, tug and heat the kinks. Thanks
Old 10-18-2013, 09:22 AM   #8
padresag
it is not that simple as weld a pull plate on and bondo up. there is a whole substructure in behind that corner
\ron
Old 10-18-2013, 09:55 AM   #9
LT1 Burb
LT1 Burb's Avatar
I think I would go at that from cutting a patch on the inside and working it out. It definately looks fixeable to me.
LT1 Burb is offline   Reply With Quote
Old 10-19-2013, 03:41 AM   #10
Kiwi 64sub
That should be fixable.The damage to my rear quarter was worse than that and I fixed it at home with minimal tools and I am no panelbeater.There should be some pics on my build thread.I cut the inner panel to gain some more access to the panel.
Kiwi 64sub is offline   Reply With Quote
Old 10-21-2013, 02:56 PM   #11
crazyhenryj
Thanks Kiwi we were checking out cutting an access hole in the inner panel from under neath to get at that nastiness.
Old 11-14-2013, 02:52 PM   #12
hemifalcon
There is no substructure behind there.. It's completely hollow.. It was recommended I cut the inner panel from my suburban to repair mine--but mine wasn't so bad.. For yours.. I'd recommend cutting it out possibly on the inside and working that out.. You may be able to save your original paint, or a large majority of it... Repairing the inner part and painting it won't be as difficult as the outside..
Remove the right tail light and take a look inside and you'll know what you're working with..
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 11-14-2013, 03:43 PM   #13
padresag
in the corner there is
here are some pics of what is in behind there
that is off the inside of the l/rear corner and it is spot welded the way round from the bottom of the rear post out to the fender and down
ron
Old 11-20-2013, 09:55 PM   #14
dannyd0ne
mine are rusted would like to find some patch panels i thought about the fleetside panels and just fabricate them in the right side is also dented and the left looks like someone bondo it before
dannyd0ne is offline   Reply With Quote
