10-27-2013, 11:54 AM | #1 |
rear diff fluid level
Still learning the ins and out of my new vehicle-2006 1500 2wd. Went to check the fluid level on the rear diff and found a new surprise. Being used to the older vehicles that fill to the bottom of the plug,at first I was surprised and thought my level was way too low. Then I noticed that the plug on my 2006 was much higher in the diff case than the older ones. Checking the owners manual I see now that the level should be 5/8"-1 5/8" below the bottom of the plug. I am used to sticking my smallest finger in to find fluid level. However if I was able to get my finger in 1 5/8",I don't think I'd ever get it out. Are there any tricks for determining fluid levels in this diff?
10-27-2013, 12:44 PM | #2 |
Re: rear diff fluid level
Me too: I stick my smallest finger in to find fluid level so that is close to the level 5/8" down. If I can touch the fluid it's good. If I can't touch it I add till I can.
Trueman |
10-28-2013, 04:44 PM | #3 |
How about using a bendy straw...??? works for me...if you bend it at 90° then snake it through the hole...take it back out and check the level...???
10-29-2013, 01:02 PM | #4 |
Actually what I tried and worked very well was a bent q-tip. The cotton end showed the presence of oil very well. Thanks guys.
02-01-2014, 08:19 PM | #5 |
I read somewhere once, to use an Allen wrench. I did and it work pretty good.
