Old 10-28-2013, 02:31 AM   #1
burbluv
burbluv's Avatar
Do these caps work with these rims?
I'm looking to pick up these original rims, they are 16X5, 6 lugs and I need to know if my caps will work on them for my 62 4WD suburban before I buy the wrong rims.
Thanks,
AJ
Bolt Pattern
burbluv is offline   Reply With Quote
Old 10-28-2013, 08:20 AM   #2
1963c-10
1963c-10's Avatar
Re: Do these caps work with these rims?
They look correct to me....but Aerotruk can give you the best answer on the 16" rims.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-28-2013, 11:42 AM   #3
burbluv
burbluv's Avatar
Wherefore art though Aerotruk?
Old 10-28-2013, 11:53 AM   #4
oem4me
Factorystock or Aerotruk63 both seem to have gone through the wheel/hubcap
fitment routine thoroughly, so they could answer definitively, however, if you are in a hurry for an answer so as not to lose out on a deal, I'd guess they will fit. Six lug means 1/2 ton, regardless of wheel size. The caps shown are for 1/2 ton, nub type wheels, which those pictured are. If they are cheap enough, just get them and hope I'm not wrong. Good luck.
Edit: call the seller and ask the approximate dimension of the nub diameter. If his measurement is even close to your hubcap opening, they will fit. Usually if a hubcap does not fit, it's not a close miss, but way off.
Old 10-28-2013, 12:10 PM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Those caps are 10 3/16 diameter. Have the seller measure the diameter as mentioned.
Old 10-28-2013, 12:12 PM   #6
burbluv
burbluv's Avatar
You mean the diameter of the nubs right?
Old 10-28-2013, 12:30 PM   #7
aerotruk63
aerotruk63's Avatar
They should though never hurts to measure.
16 inch, caps, rims
