Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Installed some "Brown Bread".PIC'S
I installed a product called "Brown Bread".It's a sound deadening material that when compared to "DynaMat" came out ahead in tests.
Anyhow I covered the whole inside of my Blazer with it.Inside the doors and the whole floor,firewall to tailgate. It took 2 days total to install.The product is a sticky tar like substance with a foil backing to it. You apply it to the area you want covered and then heat it up with a hair dryer or heat gun (this softens it) then roll it smooth with a 1" roller that was included. It cost me $120.00 for 1 roll.One roll covers 70sqft.I used 1.5 rolls because I covered EVERYTHING on the inside of the truck. Results: I like it.It makes the doors sound like a new car door when you close it...solid sounding!I have 6x9 speakers in the doors and the "Brown Bread" has improved their sound as well. I must say it is MUCH quieter in the truck now. I would recommend this product to anyone who wants some serious sound deadening. I got it on E-Bay.The guys sells it there or at his site here.$159.00 on his site.It's cheaper on E-Bay though,125.00.Do a search on E-Bay for "brown Bread" and you'll find it here. Here are a couple pic's This is how it's shipped to you.About 20lbs shipping wt. ![]() They even include a wooden roller to smooth it out. ![]() It's about 1mil thick,here's a close up of it. ![]() Here it is after smoothing it out in the door.A little bumpy as there was some rust inhibitor already on the door. ![]() The front done.I did end up doing the kick panel area's as well. ![]() The rear floor,bed walls and wheel wells covered with "Brown Bread" ![]() ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 08-20-2006 at 09:34 PM. |
computer illiterate
man that looks real good
72 2wd blazer 72 swb 4x4 |
Thanks Just what I was looking for...
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
14.1 @ 96MPH
And all of that is only about 30lb? Hmmm, very, very cool...
Project1970 - LS1 Swap Complete! ![]() |
Blazerless:-(
Did you put down rust inhibitor first in the floor before putting that down. I have some rust on the floors not bad, but I don't want to rust under that sound deadner- it looks cool and not as spendy as Line-X, I was going to Line-X my blazer inside, but now you got me thinking...
I took the bed down to metal then painted it with a roll on liner.
Here it was as I was taking the suface rust off. ![]() It looked like this before we painted it.Then of course with the overspray of the primer and paint it did not stay looking black. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 08-20-2006 at 09:37 PM. |
That's pretty slick i will have to check into that
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
computer illiterate
if you get the carpet wet will it absorb and hold water? or is it water repellant?
Will the Brown Bread absorb water? No.
It's an oil based product.Water will just bead up and stay there. If the carpet gets wet I don't see a way of the moisture getting to the metal bed.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
That is some nice work.money well spent.
on the website it says for best results put 2 layers, did you do that?? i wonder if it would be worth the money to buy the extra stuff to put 2 layers everywhere
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
That stuff looks to be just like Dynamat without the name on it. How many square feet did you get for that price?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#13 |
70 sqft per roll.
I did only one layer. Prob. if I was lining the truck for a serious sound system I'd put 2 layers on,but one was plenty for me.
#14 |
How is for insulating agaist heat and cold?
1970 k10 1971 C10 Gilbert Az |
#15 |
Bobby, the bed of my Jimmy gets really hot on long drives and almost cancels out the AC. What is the insulating effect from the driveline? Notice it any cooler? Nice job smoothing it out BTW.
#16 |
Since I've installed the stuff I've driven maybe 100 miles.I was on my way to Blazer-Fest (members of ColoradoK5 will know what that is)when my 700R4 lost the 3/4 clutch pack.
Anyhow in that limited amount of driving I did not notice any insulating effects(hot or cold) of the Brown Bread. My guess is it would have minimal insulating effects. Mike C,if your Blazer gets that hot maybe wrap your mufflers with some heat relective wrap like this. ![]() The description here hereare some other options as well My electric fuel pump for my TPI is mounted on the pass. frame rail,real close to my muffler.I bought Thermo-Tec's woven blanket and applied that to a shield I made.I then mounted that shield to the frame between the muffler and the electric pump.It works excellant! I'm woundering why your exhaust is radiating so much heat?!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 07-14-2003 at 04:53 AM. |
#17 |
Happy to be here
![]() Join Date: Mar 2000
So what the latest on this? Any of you guys or gals want to add a follow up on your results?
#18 |
Merciless Butcher
I went with the Dynamat..This stuff looks just as good. Sounds like it performs just like Dynamat and at a better price. Maybe on the next project??
Your Bought And Sold....I Got Your Soul! |
#19 |
glad this thread was brought back up! im also interested to hear how it performed....
70 longbed 496/th400/Ford 9" |
#20 |
brown bread
I bought the same stuff off of ebay and am very impressed with it. At first I stuck a small piece of it that got messed up taking it out of the tube to a piece of aluminum in the shop just to see how well it works. Cut the tube carefully and break it open to get the product out. I didn't and tried to slide it out of the tube and damaged the outer layer. When I stuck the first scrap piece on at first I could pull it back off and reposition it and wondered how well it would stick. I left it and ate lunch and destroyed the stuff trying to get it off after about 30 minutes. Evidently the longer it is on the better it sticks because after some time passes it sticks like grim death. I have only done the back of the cab to this point, but am extremely impressed with the product.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
#21 |
Did you use the entire roll or more than one for the entire job....?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#22 |
Mmmm...
BobbyK,
A bit more of explanation if you would please... to this question. It looks as though it has shrinkdown qualities similar to "shrink tuning", is that right? Or, is it thin enough that it molds real close to the metal. A little more clarification if you would plese. Also, it just looks terrific and sounds great... well sounds quiet, you know what I mean.
thx, JDY |
#23 |
No it does NOT shrink.
I formed it to the Blazer by slightly heating it with a heat gun(a blow dryer would work as well).I then rolled it onto the bed and floor of the Blazer with the wood roller they included with the Brown Bread. That is how it has conformed to the shape of the truck. It was time consumeing though. I am happy with the results.Definitly a "must do" project. I lined the insides of my doors and now when I close them they sound like a new car does when it doors are closed. Also helped "tighten" the sound of the speakers that are mounted in my doors.
#24 |
So it's permanent, right?
Never coming off even if you wanted it too? Nice job, sounds like a good product, or is that "doesn't" sound ![]() |
#25 |
Well...let's just say you'd have a HARD time taking it off.
