Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-04-2013, 02:14 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Clutch Linkage Picture
CAn someone post a picture of the clutch linkage going throught the floor/ firewall? I have a 1964 Suburban 4WD and am trying to determine if what I have is correct. I don't have a shop manual yet.
Baketown Scotty is offline   Reply With Quote
Old 11-08-2013, 01:14 AM   #2
Baketown Scotty
Junior Member
Re: Clutch Linkage Picture
Anyone have a picture of clutch rod going through floor?
Old 11-08-2013, 01:23 PM   #3
63suburban
63suburban's Avatar
took a couple for you sorry for the poor quality (mobile pics)
above & below firewall
1963 Chevrolet Suburban
63suburban is offline   Reply With Quote
Old 11-25-2013, 05:27 PM   #4
Baketown Scotty
Junior Member
Here is what I have. What is the hole for just above the clutch rod?
Old 11-26-2013, 12:31 AM   #5
63burban
Chevy addict
Speedo cable
63burban is offline   Reply With Quote
Old 11-26-2013, 02:12 AM   #6
Captainfab
60-66 Nut
If I am seeing correctly, that is where your clutch rod should be....in the round hole in the floor where it meets the firewall.
Old 11-26-2013, 08:38 PM   #7
Baketown Scotty
Junior Member
I was thinking the rod may be going through the wrong hole as the upper hole sure looks a lot cleaner.
Old 11-26-2013, 09:28 PM   #8
Sharps40
Shaq! The clutch down rod don't go thru the rust hole...it go's thru the big neat hole right next to the speedo cable hole (the smaller hole at 11 oclock to the big neat hole). Fix the rust hole though!
Sharps40 is offline   Reply With Quote
Old 12-03-2013, 05:19 PM   #9
crazyhenryj
here is mine from inside engine bay - 65 4spd - 292 6cyl - threaded rod is adjustment off actuator arm
crazyhenryj is offline   Reply With Quote
Old 12-08-2013, 01:49 PM   #10
Grandpa54
Grandpa54's Avatar
Originally Posted by baketown scotty View Post
i was thinking the rod may be going through the wrong hole as the upper hole sure looks a lot cleaner.
scotty, captainfab is correct it goes through the bigger hole just above where the rod is in your picture. It gets a cone shaped rubber boot in the hole. I dont have any pic but i just took one apart last week. I may have still have the boot. I can look if you like? Im in bako also so call if you want, mark ill pm you
Grandpa54 is offline   Reply With Quote
Old 12-12-2013, 08:31 PM   #11
Baketown Scotty
Junior Member
Grandpa54, If you would like to part with the boot I am interested.
Old 12-12-2013, 10:44 PM   #12
Grandpa54
Grandpa54's Avatar
I will check tomorrow if i still have it.
