Old 11-09-2013, 10:00 PM   #1
Hogger54
Hogger54's Avatar
235 head bolts single use?
Are the head bolts in a 235 single use bolts? Are they the stretch type, or can they be re-used?
Hogger54 is offline   Reply With Quote
Old 11-10-2013, 12:16 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 235 head bolts single use?
They can be reused. They are not torque to yield. It is best that you do replace them if they are original to the engine.
dwcsr is offline   Reply With Quote
Old 11-10-2013, 09:55 AM   #3
Speedbumpauto
Speedbumpauto's Avatar
I'd be hard pressed to buy new bolts for that engine unless I knew it had been apart many times or had obvious signs of corrosion or abuse. Those were tough old engines and they're not holding a lot of compression. JMO.
Speedbumpauto is offline   Reply With Quote
Old 11-10-2013, 12:30 PM   #4
_Ogre
_Ogre's Avatar
reusable bolts
shop air compressor timer
Old 11-10-2013, 01:20 PM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
Exactly.
Back in those days no ever gave a thought to such a thing as "torque to yield". This is where current era technology is overkill when working on 50-60 year old equipment.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 11-10-2013, 01:53 PM   #6
OrrieG
OrrieG's Avatar
Those engines were designed to be overhauled by farmers in the barn. Just torque them to specs then during the first valve adjustment after running it for a while check them again. This assumes they are in good shape and the engine hasn't been sitting for 50 years with the valve covers off in the rain.
OrrieG is offline   Reply With Quote
Old 11-10-2013, 02:16 PM   #7
Hogger54
Hogger54's Avatar
Sweet. They are in good shape.
I was just doing some research on it and couldn't find any info, or bolt kits for sale.
