for those interested in high to low hump changeover
The High hump was for the 4 speed manual stick shift tranny, it was needed to clear the height of the trans and was able to be unbolted for trans removal.
The low hump was for 3 speed maual and automatic trans, this gave you much more floor space and leg room. I have found several 1963's that had a bolt in low hump, this makes a great donor for the changeover because even though you still have to change the small piece in front of the hump attached to the firewall, it bolts in where the high hump came out.... a lot less welding Here is one I did today , simply unbolt the high hump and remove. then drill out all the spot welds on the lower firewall piece and remove. Then test fit your donor pieces, clean up the spot weld area and spot weld it back in. Bolt in the low hump and your done
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
Re: for those interested in high to low hump changeover
Final pic...
1963 is the only year I have found a bolt in low hump, not sure if all 63's had this or not maybe some of the 63 guy's can chime in. 63 is the only year I have seen them in and I have seen a few. I know where 1 more is in a junk yard, they had 2 but crushed 1. the nicest one of course!
I have a 65 cab with a great floor. I don't have a high hump, but I could buy a 63 low hump from a guy in my neighborhood. What advantages would a low hump floor have - other than a little more leg room? I plan to install a T5 floor shift tranny and I think the low hump floor would be the best. Right?
Here's my cab floor. Yeah, it has a hole that needs repair, but otherwise the floor is really solid.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
You have the typical low hump , no need to do anything but patch the hole
1961 crewcab
I am pretty sure that all the 60-63 low humps were bolt in.
in 64 they started welding them in...although there have been a few pics of post 63's with a bolt in low hump... I pulled a low hump out of a 64 80 series, it was the 409 with the Allison 5 speed, the tunnel was a low hump , but it does have a hole for the shifter, the neat part is the front piece which is usually welded in on the 1/2 tons was bolted in on this truck. these big trucks usually have a flat panel on the floor. save , and sell that left over high hump, all the guys converting to a dropmember need a high hump. I think I have sold about 5 of them out of my junk cabs.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
I had to raise up the middle a little to clear the T5. I think it was about 2". I had several guys tell me the small hump was always welded in. So I started bring mine with me. The stock carpet fits.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Does the front section always weld in & does the back section always bolt in?
#8 | |
Front usually is welded in, but I have seen a couple c60 and c80 that bolted in Rear is usually welded on a low hump, but I have seen some 60-63 with a bolt in low hump Rear bolts in on a high hump ( 4 speed ) models
Enjoy your truck
I have been trying to find a bolt in low hump for my 63 and I thought all the 60-66 trucks had bolt in panels. I didn't realize later years had weld in panels.
Now I realize why I haven't found one yet. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Yeah, until recently, I didn't know that either.
I keep watching the classified section.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
I know where 2 are, maybe I need to go get them and post them up!
I thought the high hump was more desirable for t5, etc swaps? Here i was sad that i didn't have one
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
#13 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by 70cst; 12-01-2013 at 01:53 AM. |
#14 |
I pulled a bolt in low hump out of the 61 in my yard. My 63 has a bolt in low hump also. The 61 was a St.Louis truck and my 63 is a Baltimore truck
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#15 |
I've got a high-hump in the Suburban now, and will be converting to low hump... then I'm going to convert the factory high-hump to a center console with cup holders, small storage tray, and a factory cigarette lighter for a power port.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#16 |
67cheby
![]() Join Date: Sep 2008
great information , looks like i am going to be on the hunt for a high hump !
