Old 11-21-2013, 03:54 PM   #1
jbassC10
Wisdom for Drums to Disc Swappers:
I found this "Bracket" which is needed to switch front brake drums to disc on most old school C10's with original drum brakes: ((original brake drums on C10's have bolts sticking out of the firewall to conect the master cyclinder to, which comes into problems when attaching a new or old booster which has bolts sticking out of it)) So Bracket is needed:
Note: I tried summit racing bracket for this problem= NO GO. :-\
Anwser: I believe I pulled this bracket off of a 71 or 72 GMC (again GMC) [junk yard owner didn't say what year truck I pulled the bracket off of, but I believe GMC put disc on since 1970=bracket]
After pulling this bracket it fit PERFECT to my 69 C10 fire wall bolts. No fabricating at all! Unscrew=Screw in! That easy!
Make sure your getting the hole bracket/rod and all. Because the rod on the back of the brake pedal under your dash unscrews which goes through the firewall and the new bracket rod screws in! Real simple if you got the original parts on the bracket.
Hopefully my pictures will explain it better.
jbassC10 is offline   Reply With Quote
Old 11-21-2013, 03:56 PM   #2
jbassC10
Re: Wisdom for Drums to Disc Swappers: more pics
Back of the Brake Booster you see the gold rod sticking up with the loop on the end of it: The connects to top side of the bracket.
Old 11-21-2013, 03:58 PM   #3
jbassC10
Sanded and Painted!
Old 11-21-2013, 04:09 PM   #4
jbassC10
Above the rode has a nut and threads on it: well the rod screws into the female little bracket attached to your brake pedal under the dash. The nut is not NEEDED in this swap, it was placed apprently by accident from the owner hoping the rod wouldn't un-thread itself from the brake pedal bracket. Well it won't be able to, one end of the rod is connect to the bracket not by threads.
Old 11-21-2013, 04:15 PM   #5
tony58
Those are available brand new, complete and bolt on, without the rust!
tony58 is offline   Reply With Quote
Old 11-21-2013, 07:01 PM   #6
71 super
71 super's Avatar
Nut is there from factory
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-21-2013, 09:43 PM   #7
jbassC10
Where do you get it at? haha I wish I would have know that before hand with all the questions and junk yards I visited.
Okay thanks on the bolt!
Old 11-24-2013, 10:57 PM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
You have just constructed a stock OEM 67-72 1/2T PB system. You could just go take on off of any stock truck.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 11-24-2013, 11:33 PM   #9
jbassC10
Okay, man I Hope whoever reads into the conversations were having on my "Swap" drums to Disc really helps them out!!
Thanks!
bracket, disc brake conversion, disc swap
