Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Do you have a Crushed, Accidented, Dinged , Dented 63 grill
Looking for the two supports 1.266. These attach the grill to the panel assembly. Need the left and right side. Please.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
![]() Join Date: Aug 2008
Re: Do you have a Crushed, Accidented, Dinged , Dented 63 grill
are 63 different than 64-66?
I have a whole dented up 63 aluminum grille I will let you have for $100. if interested let me know I will send you photos.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
Since the grill support changed from 63 to 64, I'm assuming the supports changed as well.
Cant help you then- sorry.
![]() Join Date: Jun 2007
I may have a steel 63 grille you can get for 50-75 dollars or so - let me look to see if it has the mounting brackets first...will PM if so
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
I have asked Rene (c-10 king) this question and says he never has to change the light mounts to add '63 grills to his trucks. He says they all line up, just the grill itself is deifferent. Just to let you know, you might want to try it first.
Well stopped in Gladstone Michigan on the way back, this guys son has a 63 and they have a dozen or so different years parts trucks. He had two sets of supports already removed from the 63 grill face. Got a left and right support.
Life is sometimes good. Thanks to all who tried to help.
