Old 11-22-2013, 10:50 AM   #1
1972GMCsierra4x4
Dash heater box removal
What's the easiest way to remove the under-dash heater box on a 72 gmc. I've got a bunch of leaves and mouse poop in mine and it needs cleaned out BAD!
1972GMCsierra4x4 is offline   Reply With Quote
Old 11-22-2013, 11:09 AM   #2
OLDGREY
OLDGREY's Avatar
Re: Dash heater box removal
I just removed mine in a 72' jimmy for the same reasons. Whatever was living in there chewed the fan also! The easiest way that I've found is to remove the inner fender on the passenger side first. This will allow you the best access to all the bolts on the engine side of the heater. Some of the bolts go thru both the outside box and the inside box. Be careful not to mess up any of the gaskets unless you plan on replacing them. I then took all the parts and soaked them in a tub of soapy water and scrubbed them clean to get all the mouse stuff off. This would be the perfect time to replace the heater core and the fan motor. I also put some screens on the vents in the cowl to keep out the big leaves and debris. Hope this helps.
Old Grey-Grandpa's 1969 C-10 SWB in limbo.
1972 GMC Jimmy 4x4, soon to be a driver.
1972 C-10 Custom, daily driver.
Bad decisions make great stories!
OLDGREY is offline   Reply With Quote
Old 11-22-2013, 11:09 AM   #3
quick60
quick60's Avatar
Check this out
http://67-72chevytrucks.com/vboard/s...eater+core+box
I suggest removing the inner fender. It is very easy. I also remove my hood but I was doing a lot more than just the heater core but it was definately nice. I also loosened the top bolts on the fender to pull it away from the truck to install with the new gasket in place. The hardest part of the operation was reinstalling with the new rubber boot on the new heater box and keeping it on while fitting everything up.
quick60 is offline   Reply With Quote
Old 11-22-2013, 11:19 AM   #4
1972GMCsierra4x4
I'm not talking about the one in the engine compartment. I've already cleaned that out, replaced the core, etc. etc. I'm referring to the one underneath the dashboard that the windshield defrost ducts are connected to.
Old 11-22-2013, 11:34 AM   #5
OLDGREY
OLDGREY's Avatar
There are a few nuts in the engine compartment that you will need to remove in order to get the heater box on the inside out. There are also some on the inside of the cab to remove. Drop it down and remove the heater control cables. It then should come out.
Old 11-22-2013, 11:35 AM   #6
71K20chevy
71K20chevy's Avatar
I had to take my glovebox out to get to the screw on the top.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 11-22-2013, 11:38 AM   #7
1972GMCsierra4x4
Alright thanks guys. On a side note, how do you add a picture to your profile on here
Old 11-22-2013, 11:41 AM   #8
OLDGREY
OLDGREY's Avatar
Go to user CP at the top and then go to edit Avatar.
Old 11-22-2013, 12:39 PM   #9
1972GMCsierra4x4
1972, gmc, heater
