Old 11-23-2013, 12:01 AM   #1
Propane350
Heater Core Removal/Bypass Question
So, question for all you fellow gear heads out there:
I'm removing the under hood black box containing my heater core and fan from my '68 C10 to make room for a, larger, custom glove box and instead, using a smaller electric heater and fan set up.
My question is: If I remove the heater hoses and plug off the ports on both the water pump and the intake manifold, will that cause any issues? Or should I just run some heater hose between in the in and out ports, instead of capping them off?
The main reason I ask is, a few years back the heater core went out on my 72, so I just caped off the ports, then a few weeks later my water pump went out.
Just wondering if that was just a fluke, or if stopping the flow maybe raised the pressure in the pump enough to blow the seal? I dunno.
Long story short: I just built the motor and I don't want to start tearing up water pumps for no reason.
Propane350 is offline   Reply With Quote
Old 11-23-2013, 12:28 AM   #2
zeldman
zeldman's Avatar
Re: Heater Core Removal/Bypass Question
Capping the ends shouldnt be a problem. Or you could run a hose between the ports and let it flow. Your earlier problem with capping the ports was just a fluke. Either way will be fine.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 11-23-2013, 01:31 AM   #3
Propane350
That's what I was figuring. Just wanted to hear someone else confirm my thoughts.
Thanks!
