Old 12-01-2013, 10:05 AM   #1
Matthewjb
Door repair question
Hey guys I have a question regarding rust on doors. I'm a novice at bodywork and wanted to get y'all's opinion on how to fix. The doors are in great shape other than some rust on the bottom, right on the bottom where the doors begin to curve up.
Matthewjb is offline   Reply With Quote
Old 12-01-2013, 02:49 PM   #2
72bowtiestepper
Re: Door repair question
A pic or 2 would help us see where the rust is & give you advise how to repair. Door skins are avail. from the aftermarket to repair rust , as well as bottom of the inside of the door patches. Don't just throw bondo on the holes...the rust must all be cut out or you will be doing the same repairs over & over......not fun at all.
72bowtiestepper is offline   Reply With Quote
Old 12-01-2013, 03:24 PM   #3
burnin oil
Without even looking at them I will tell you this from experience. Plan on alot of patch panel work. The doors rust from the inside out because dirt and leaves plug up the drain holes at the bottom of the door. What looks minor will actually be to thin to weld. I just went through this when reworking my doors. Looked good until you try and weld to it and it blew through like it was tin foil! If you sand blast it there will be alot more holes also.
burnin oil is offline   Reply With Quote
Old 12-01-2013, 03:28 PM   #4
Matthewjb
Here are some pics. Sorry about that. This is both of the doors. Name:  photo 2.JPG
Old 12-01-2013, 03:32 PM   #5
burnin oil
Plan to replace everything below about 1" up from the bottom inside part of the door. While you are having fun it is a good idea to reinforce behind the door hinges.
Old 12-01-2013, 03:33 PM   #6
Matthewjb
Other than this doors are in pretty fair shape
Old 12-01-2013, 03:51 PM   #7
Mike's money pit
I think board member ebfabman sells videos covering common rust repairs on our trucks. I have not seen the videos yet (I intend to buy them at some point) but I read somewhere they include repairing doors. Maybe someone can chime in who knows for sure. Here is a link to the videos: http://ebfabman.com/id27.htm
Mike
Mike's money pit is offline   Reply With Quote
Old 12-01-2013, 06:05 PM   #8
Molberg
Molberg's Avatar
https://www.youtube.com/watch?v=YurQpXIdWM4
i stumbled across this while fighting with my doors... he makes some great points to observe if you're going to cut out the complete tub.
Molberg is offline   Reply With Quote
Old 12-02-2013, 11:41 AM   #9
Matthewjb
Thanks for the info guys, I'm debating on wether or no it would be worth it just to buy after market doors. Im not sure how much $$ I would sing into buying all components and the shell...anyone have a rough guess on that?
Old 12-02-2013, 11:58 AM   #10
Molberg
Molberg's Avatar
I've heard some horror stories about after market doors. Rep at LMC told me they're "hit and miss". Hit in spots and miss in others. May have to drill spot welds on upper window frame to re-align. Wow. I found some decent factory doors at local scrap yard that required minor repair to corners of door skin vs entire tub.
Old 12-02-2013, 12:07 PM   #11
In The Ten Ring
I'm fearful of many aftermarket parts, I'd spend the extra money and effort to get original doors from say NM, CA, or AZ.
In The Ten Ring is offline   Reply With Quote
Old 12-02-2013, 01:03 PM   #12
72bowtiestepper
Here are some pics. Sorry about that. This is both of the doors. Attachment 1181866
Attachment 1181867
Those doors are not too bad....a lot better than mine were. If you have a mig welder & some basic bodyworking tools, try to do the repairs yourself...it's not really that hard. Use the utube vid. as your guide...it is very informative.I agree with others about the aftermarket door shells....keep as much of your stock GM doors as possible....Just my opinion.
Old 12-02-2013, 02:50 PM   #13
Lattimer
Lattimer's Avatar
My doors were about the same but also rusted through both corners of the outer skin. I spent about $80 on the patch panels and the body shop is charging me $450 per door to do the repair. That is bring them the truck, they do the repair and paint, hang and realign the doors. One is done and they are in progress on the other now.
So call it $1000 for the repair.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-03-2013, 11:09 AM   #14
72bowtiestepper
Good bodywork is NOT cheap....that's why I do my own....takes a lot of time to do it right, but I'm in no hurry. You do get a lot of satisfaction when it's finally done though !
Old 12-03-2013, 11:20 AM   #15
burnin oil
As others have told you. A little practice and patience with a few basic tools (welder and body hammer set) will reward you with divedinds. The biggest trick is learning to replace a decent amount past the rust with out being tempted to replace the entire panel. In other words you learn to cut up a perfectly good patch panel so that you are only replacing whats needed.
Old 12-05-2013, 08:49 AM   #16
ebfabman
Here is 6 hours of door repair in about 4 and a half minutes. Hope it helps.
ebfabman is offline   Reply With Quote
Old 12-05-2013, 09:01 AM   #17
72bowtiestepper
Thumbs up Re: Door repair question
That's a great vid. Thanks for posting it ! Wish I could work that fast !
Old 12-05-2013, 02:49 PM   #18
mcbassin
Still Learning
mcbassin's Avatar
What a STUD! You make that repair look easy. Thank you for sharing it..... I'm pretty sure the average guy would spend much more than 6 hours. I know I worked on one of my doors for over a week every day after work. I only replaced the lower section not the outer skin.
mcbassin is offline   Reply With Quote
Old 12-05-2013, 06:23 PM   #19
motorcritter
motorcritter's Avatar
Sitting at the feet of a master! I just might give it a try- good doors are hard to find, and not really cheap when found.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 12-05-2013, 10:39 PM   #20
engineer_gregh
engineer_gregh's Avatar
Subscribed. Great thread
engineer_gregh is offline   Reply With Quote
Old 12-06-2013, 06:02 PM   #21
RaceAGMC
RaceAGMC's Avatar
door repair.wmv - YouTube
Is that you doing the repair?
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 12-08-2013, 02:25 PM   #22
ebfabman
Me?.......Yes, but no remarks about the bald spot.......
Old 12-08-2013, 07:13 PM   #23
RaceAGMC
RaceAGMC's Avatar
Oh no. Nothing like that, I've got a bald spot myself. I was just asking cause you are a local guy. It looks like I could learn something from you. Do you go to any shows?
Old 12-08-2013, 09:36 PM   #24
ebfabman
Just kiddin.....I don't have a bald spot...hahaha.......I'm in Concord near the speedway.
Old 12-08-2013, 09:44 PM   #25
brans72
You can find used doors on Craigslist. I would buy used before a aftermarket door.
brans72 is offline   Reply With Quote
