12-07-2013, 08:41 PM | #1 |
Frame paint
Hello everyone, I've been lurking for a long time so I figured It was time to ask a question. What kind of paint do you use to paint the frame back to the factory satin black? Thanks in advanced-JP
12-07-2013, 09:00 PM | #2 |
Re: Frame paint
I have used Bill Hirsch chassis paint for years with good luck. But there are many others that also work great..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
12-07-2013, 09:00 PM | #3 |
Re: Frame paint
I used an industrial tractor paint that looks phenominal.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
12-07-2013, 09:42 PM | #4 |
Re: Frame paint
Rustoleum code 7777. You can buy it in quarts, gallons and spray bombs almost anywhere and its easy to use and touch up.
12-07-2013, 10:04 PM | #5 |
Re: Frame paint
Welcome to the site from the eastern part of frozen Arkansas. I am A born bowtie lover bleed bowtie Orange and own a bodyshop here in a small farming town of about 4500. I rebuild late model wrecks for a living for fun I do old muscle and trucks. there are tons and tons of great help on here. As soon as you can go to the home page click the home in the upper left corner then click on tech tips then your style of truck and enjoy. There is always something helpful there. I have and will again use the PPG's DPLF 90. It is an epoxy primer in black. I have used it on everything from a frame to a core support and not only does it last real well it looks great. Jim
12-07-2013, 10:23 PM | #6 |
Re: Frame paint
HotRod:
Whats the brand and information? I would be interested in researching this option a little bit.
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
12-08-2013, 07:50 AM | #7 |
1969 Custom 30 wrecker
Re: Frame paint
Anyone use GM recondition black? I was thinking of trying it but seems hard to find. ??
Anyone know where to get some?
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
12-08-2013, 11:27 AM | #8 |
Re: Frame paint
I will get the info today....
12-09-2013, 03:56 PM | #9 |
Re: Frame paint
Thanks for all of the responses everyone. Has anybody ever had any experience with the Eastwood chassis paint? -JP
12-09-2013, 04:28 PM | #10 |
Re: Frame paint
i am giving valspar tractor and implement enamel a try. i havent startyed yet as im researching if brushing or spraying on is best and methods of stripping the frame etc.
i heard good things about the valspar so i figured i would get it to try.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
12-09-2013, 05:49 PM | #11 | |
Re: Frame paint
As hugger6933 stated earlier in this post, PPG's DPLF 90 is the cats meow if you want the best, most durable finish. But read, expensive and harder to use, and use a good respirator. I use the Rustoleum 7777 because I drive most of my cars and I can walk into any WalMart and buy touch up paint. I have a trailer queen Corvette and Chevelle that have the DP 90. |
12-09-2013, 06:50 PM | #12 |
Re: Frame paint
Used Eastwood chassis and Tractor paint both, didn't see any bigger advantage to either one. I think just compare the cost unless it is spending it's life on a trailer from now on.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-09-2013, 06:56 PM | #13 |
Re: Frame paint
Here is the info:
Valley Paint Manufacturing Super Speed Satin Black V-2507 and I added Their Enamel Kicker to it. V-3001. This stuff reduces with Zylene
