12-09-2013, 12:46 AM | #1 |
Future TOTM Winner
Trans cooler lines???
The 72 stepside in my signature has the original steel lines running from the auto trans to the factory style radiator and they have seen better days. I was wondering what all is out there as a flexible replacement? Could I just get some quality rubber fuel line and hose barbs with the appropriate fittings? I know stainless braided line is an option but this truck doesn't need that kind of money thrown at it. It's far from stock at this point and I am more worried about function than form.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
12-09-2013, 08:18 AM | #2 |
Re: Trans cooler lines???
The best solution is to get more steel lines and bend them yourself in the needed configuration.
You can run rubber lines, but it MUST be rated for ATF. Fuel line will degrade and blow/leak in a very short time. |
12-09-2013, 11:58 AM | #3 |
Future TOTM Winner
Thanks Zane, the line degradation is what was concerning me. Needs to be more of a hydraulic line I guess. I have considered bending my own lines, I just hate fighting the tube. I have a bad track record of ruining tube and spending a crapload of time and money. Flexible line just seems so much easier.
12-09-2013, 12:13 PM | #4 |
The Older Generation
Not sure what your budget is for the lines but this stuff is the nuts. You can bend it with your hands without kinking it and if you get it wrong you can straighten it back out and re-bend it. It flares really easy too. http://www.ebay.com/itm/CNC525-5-16-...55994d&vxp=mtr Oh, and it won't rust.... LockDoc
12-09-2013, 12:16 PM | #5 |
You could always go to a scrapyard and pull some from a 73-87. I think they are the same.
12-09-2013, 02:13 PM | #6 | ||
"I ain't nobody, dork."
The only thing I have ever bought from LMC for my truck is prebent steel lines for my factory auto tranny cooler. Same ones you are looking to replace (from tranny to radiator). I know people loathe LMC on here... but... they fit perfectly.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
12-09-2013, 03:23 PM | #7 |
Future TOTM Winner
I'm not against buying some pre-bent lines but I'm not sure what I need exists. The truck is a factory style 4 core radiator, but the engine is an LSx 6.0 with a 200-4r transmission. So the length that the lines need to be is different than a factory th350 sitting in it's stock position (I think). When I got the truck it already had the 200-4r in it with a small block engine, I put the LS 6.0 in but I left the transmission and crossmember exactly where it was. However, it looks like the guys before me bent the crap out of the original th350 lines to make them fit the 200-4r. That's what has got me to the situation I am in now.
12-09-2013, 03:24 PM | #8 | |
Future TOTM Winner
12-09-2013, 04:57 PM | #9 | |
LockDoc
