Engine question
I have the original engine in my 70 c10. It runs ok but it smokes.
I have a 84' 350 with 30-40k on it that I am planning to swap. My question is will all my accessories bolt up to the 84? I also have a th400 with low miles. Is it worth replacing my original leaky th350? |
Re: Engine question
Is the original engine a 6 cyl or an 8? A origional 350 will have a short water pump, the 84 will be a long water pump so all the pully's and brackets will need to be transferred with the engine.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#3 | |
Re: Engine question
So all the brackets are the same? |
Re: Engine question
You'll need to replace the water pump on the 84 350 with a "short pump" for a 70 350, then all of the brackets and pulleys will fit the newer engine. The TH400 is a great trans but it won't just drop in place of the th350. Driveshaft slip yolks are different, th400 is longer so the driveshaft may have to be shortened, depending on the length of the th350.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD ![]() 1970 Chevy Nova - Street and Strip Project ![]() 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
#5 | |
Re: Engine question
I'm shortening my frame son I'll have to do the driveline anyway so it might be a good time to swap out the tranny. Is the linkage the same? |
#6 | ||
"I ain't nobody, dork."
Re: Engine question
The TH400 will rob a bit of power from that 350. They are made to handle the TQ of a BBC. Even though some were put behind 350's in these trucks from the factory in HD applications. The TH400 is prolly the best old school slush box The General ever made.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Re: Engine question
depending on what your doing for exaust, the dipstick might be an issue. the moved the dipstick to the other side of the block in the 80's. The 70 manifolds will not work on the 80 up engines. if the 84 has manifolds, they might not fit back to your exaust. if your using headers.......nevermind.
Re: Engine question
Interesting point. The TH350 is working well just a little leaky. maybe I'll just reseal the Th350 and sell the 400.
#9 | |
Re: Engine question
Re: Engine question
I think its 80-85 the dipstick was relocated to the passenger side of the motor. I know my motor is an 84 and its on the passenger side. I run headers and have no fitment problems.
#11 | |
Re: Engine question
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
