Old 12-09-2013, 02:13 PM   #1
Rattletrap
Motor ID?
I have 1972 blazer the casting # on the block is 1MQ629 with 4VP under that an any info on the motor would be great.thanks
Rattletrap is offline   Reply With Quote
Old 12-09-2013, 02:14 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Motor ID?
Where is that located? Back of the block on the drivers side near the tranny? That's where the casting number should be.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-09-2013, 02:16 PM   #3
Rattletrap
Re: Motor ID?
front right side below the head cold stamped.
Old 12-09-2013, 02:20 PM   #4
GASoline71
GASoline71's Avatar
Re: Motor ID?
That's the suffix code area. Look for the casting number on the back of the block. That in conjunction with the suffix code will narrow it down.
Gary
Old 12-09-2013, 02:22 PM   #5
Rattletrap
Re: Motor ID?
I'll take alook when i get home.Thanks for the help.
