Old 12-09-2013, 07:08 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
1969 GMC headlight conversion and wiring questions.
Are the headlights 5 3/4" or 7"??
I don't have the truck with me right now, but I'm looking to buy a pair of low beams conversion where all I have to replace is just the bulb and not the whole unit.
Also, can I use the stock wiring or will I need to buy an adapter to work with the new headlights??
I made calls to after market places, but can't get a straight answer.
Thanks.
desert-rat is offline   Reply With Quote
Old 12-09-2013, 08:04 PM   #2
463
463's Avatar
Re: 1969 GMC headlight conversion and wiring questions.
Cibie H4 & H1 headlamps • 5.75” round for the low and hi. These have a H4 for the low and H1 for the hi beam. Note with this light upgrade I recommend the head lamp relay wire upgrade is installed in the truck. link http://www.madelectrical.com/catalog/rly-1.shtml
here is a link http://www.danielsternlighting.com/p.../products.html
Or the seal beams from http://www.sylvania.com/en-us/applic...n.aspx#fldYear
Trueman
463 is offline   Reply With Quote
Old 12-09-2013, 08:19 PM   #3
Ole Greenie
Ole Greenie's Avatar
Thanks.
We have 7" headlights. IMO, this is a real easy upgrade. Go down to the local pick-a-part and pull off 2 5-prong square relays. Do a search for the upgrade wire diagrams and install it all your self with good 14/16 gage wire from Autozone... You will save a ton. The headlights can be had on Ebay for less than $45. Total in mine was $60, and bright as heck!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 12-09-2013, 08:26 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
"We" as in chevy owners have 7" lights but desert-rat has a GMC emblem under his name with tells me he has 4 head lights. They are not 7", they are smaller. I don't know the exact dimension but 5.75" sounds about right. I'm sure a GMC guy will chime in here in a second.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-09-2013, 09:11 PM   #5
463
463's Avatar
Chev is 7" lights (2 headlamps) GMC is a 5.75” light (4 headlamps) setup.
Trueman
Old 12-09-2013, 09:23 PM   #6
desert-rat
So buying the head lamp relay wire upgrade will come with everything that I need to get the headlight conversion to work??
Old 12-09-2013, 09:47 PM   #7
463
463's Avatar
In most cases the kit is complete , you may want to move or relocate to you liking and that may require more wire. you need 2kits hi and low.
Trueman
Old 12-09-2013, 10:54 PM   #8
desert-rat
So all and all, this is a pretty straight forward install??
Old 12-10-2013, 10:36 AM   #9
463
463's Avatar
Yes! It's one of the top five upgrades for my money.
Trueman
Old 12-10-2013, 11:58 AM   #10
Warrens69GMC
Warrens69GMC's Avatar
LMC Truck has your harness already made with both high and low beam relays $29.99+ shipping.
part -36-3581
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=76
Old 12-10-2013, 01:32 PM   #11
desert-rat
part -36-3581
Will this wire complete the installation or do I need to get the headlight bulb adapter to work with the conversion bulb??
