Old 12-09-2013, 08:18 PM   #1
dmartin1
dmartin1's Avatar
no factory rivets?
What would be a likely cause that you would think of?
1969 swb
Someone replaced every single rivet (very front cross member, ball joints, even the brackets from the frame for the sway bar.literally everything) has been bolted.
Just seeing what others may think? Maybe they undid it for frame straightening at one time?
The suspension stuff is always likely to have been rebuilt.no big deal.just makes me curious why every cross member etc would be.I know bits a wild guess.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 12-09-2013, 08:30 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: no factory rivets?
The rivets tend to wear and allow slop in the frame rails especially up in the front with all the power steering forces. The frame rails on one of my trucks used to literally come together and separate about a full inch when cycling the steering when there was no front bumper on. On yours someone might have restored the truck at one point, found a worn rivet or two, and decided just to change them all. It's not all that uncommon.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-09-2013, 08:38 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Accident? Frame straightened and they installed a new front cross member with bolts?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-09-2013, 09:15 PM   #4
RANDY COX
RANDY COX's Avatar
my whole frame has been replaced with grade 8 hardware...done by the PO.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-09-2013, 10:58 PM   #5
dmartin1
dmartin1's Avatar
i wonder this as well. because the front framehorns where the bumper mounts are like cut/torn. at first i thought to accomodate a different bumper, but it looks like it may have happened from an accident.
the frame appears to sit bent over to the driver side a hair, but when measured is square.(going of a point on the cab) any other sure fire ways of verifying its straightness?
everything as far as the front suspension crossmember seems to look fine and square like nothing to make me suspect a bent frame.
65 nova
And more
Old 12-09-2013, 11:52 PM   #6
old Chevy guy
old Chevy guy's Avatar
If it looks good and goes down the road straight I wouldn't sweat it.
old Chevy guy is offline   Reply With Quote
