12-09-2013, 09:57 PM | #1 |
ZZ454 header fitting
Okay guys I have a 72 C-10 that I just bought a ZZ454 for. I know some people had questions on the fitting of long tube headers so I thought I would post some pictures. The bottom flange of the header was interfering with the lower head bolts. So they did need to be notched out. I used a die grinder with a carbide burr. Before fitting you will probably want to tape the exhaust ports to prevent any metal filings from entering the head. Hope this helps!
12-09-2013, 10:10 PM | #2 |
Re: ZZ454 header fitting
Here is the flange notched out
12-09-2013, 10:13 PM | #3 |
I taped the exhaust ports off to prevent any filings entering the head.
12-09-2013, 10:18 PM | #4 |
The carbide burr that was used...
12-09-2013, 10:22 PM | #5 |
Hope you can see how close the fit is.
12-09-2013, 10:35 PM | #6 |
The old girl that is getting a new heartbeat!
12-09-2013, 10:37 PM | #7 |
mine did the same thing, die grinder and all was well.
12-09-2013, 11:59 PM | #8 |
I bought Hooker headers because I thought they would fit...NOT! I had to do the same thing but I used an angle grinder. Only problem is if you have ceramic coated headers (like I do), there goes part of the coating and any warranty on the headers is gone also.
