Old 12-10-2013, 11:10 AM   #1
Matthewjb
Disc conversion or Suspension upgrade first?
Hey all, wanted to get you opinion on this. I'm planning in the next wk to either get disc brakes or suspension. Is there any preferance of order that I should purchase?
Matthewjb is offline   Reply With Quote
Old 12-10-2013, 11:13 AM   #2
BMERDOC
BMERDOC's Avatar
Re: Disc conversion or Suspension upgrade first?
All depends on the condition of the components. What do you need worse? Are you lowering it? Do you have a budget?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-10-2013, 11:13 AM   #3
Tork?
What are your long term goals? That will help you match up what to get.
If you're looking for a stock like ride with a small drop, then I would get a basic disc conversion first. If you're looking to get more hardcore with upgraded control arms etc and a big brake kit, I would do suspension first.
Tork? is offline   Reply With Quote
Old 12-10-2013, 11:15 AM   #4
Matthewjb
Nothing short term since everything is ripped down to frame. As for teh stance, I dont want it to be a lowrider but I want to sit low enough to handle well. Def want better than a stock ride. This truck will have some power behind it.
Old 12-10-2013, 11:16 AM   #5
Matthewjb
Yes I have a budget, Iv'e got about 1600 to spend right now.
Old 12-10-2013, 11:24 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
What do you mean by "suspension." Do you mean modified upper and lower control arms, etc? or do you mean "lowering"?
Because if you're swapping spindles to convert from drums to disc you might as well do it all at once because you can buy a dropped spindle to get some of the drop and get the rest with springs. Since the whole thing is apart, now is the best time to install all new bushings, ball joints, tie rod ends, etc. I don't think a drop and disc brake upgrade should be more than your budget.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-10-2013, 11:27 AM   #7
Matthewjb
I dont think I will buy new control arms, but I will rebuild with a front end rebuild kit---new bushings tie rods, etc as you mentioned. However, I do want to put sway bars and changing to 5 lug, etc.
Old 12-10-2013, 11:31 AM   #8
MARKDTN
They really go hand-in-hand. Need to do front suspension with a brake swap together.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-10-2013, 11:34 AM   #9
russgoodman
russgoodman's Avatar
ECE will do a combo drop kit/front disc brake conversion package if you call or email them. It was under $1300 I believe. Now if you are doing a 4 wheel disc conversion thats another story.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 12-10-2013, 11:36 AM   #10
Matthewjb
Ok good deal I will give them a ring..No I think I'm going to keep drums in the back and disc up front.
Old 12-10-2013, 11:43 AM   #11
67ChevyRedneck
Have you seen the stuff from this company? They have conversion kits/drops, etc. They also have axle conversion kits for the rear if you don't want to find a 5 lug rear axle.
http://earlyclassic.com/catalog.aspx
Jesse James
Project "On a Dime"
Old 12-10-2013, 12:08 PM   #12
CC69Rat
CC69Rat's Avatar
If you go with ECE - Talk to Stan. Tell him you're a forum member and there is a discount available. I think it's 10%, .. but 10% of $1300 is significant. Good luck man, Stan will fix you up. Just a reminder 63-70 balljoints are different than 71-72. You'll want to make sure they match up with your spindles (if you do dropped spindles) I'd suggest replacing the balljoints while you have it apart, not so easy to do but well worth the effort after it's done. Just make sure if they give you 71-72 spindles you have 71-72 balljoints, or 63-70 same idea. I'm 100% sure Stan will take care of you just tell him what year your truck is .. etc. etc. Just a heads up.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-10-2013, 01:26 PM   #13
Matthewjb
Awesome. I just called Stan and he was great. I think I have something in mind. Thanks for all the help!
