12-10-2013, 04:49 PM | #1 |
Did Chevy make a C-series 4x4?
Just picked up a SWB 4x4. It's titled as a 1972 C10, but I believe it's a '71 because of the rearview mirror location (ceiling) and door panels (vinyl, not molded plastic). This truck hasn't been lifted and I know it's been 4x4 for at least 25 years (so if someone converted it, it was a long time ago). The truck came with a box of trim that came off it during its recent paint job, and there are well-worn Cheyenne 10 badges.
My question is: Did Chevy make a C10 4x4, or were there K-series Cheyennes? Everything I'm finding indicates that C-series = 2wd, K-series = 4x4, but I thought the Cheyenne package was only a C-series thing. Am I mistaken somewhere, or could this be a really old conversion? Photo attached just for kicks. |
12-10-2013, 04:57 PM | #2 |
Re: Did Chevy make a C-series 4x4?
All trucks whether be Cheyenne or custom or bare bones were either classified as C= 2WD or K=4WD. So it could be a c10 or c20 an it will be 2wd. Just as k10 or k20 it will be 4wd.
Probably back when the truck was new or newer someone decided to make it into a 4wd conversion. Maybe look for the VIN on the frame an see if it matches the one on the door jamb plate. Do the find match with the title and what's on the truck? Could've had a cab swap an they swapped the plates too. |
12-10-2013, 04:59 PM | #3 |
Just like to part out trucks!!
Cheyenne10 could of been a 1/2 ton 4x4, whats your first letter on vin number, it should be K. The only place that says K is on vin plate. Someone probably did a cab swap if the mirror is mounted on the cab.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 12-10-2013 at 05:06 PM. |
12-10-2013, 05:04 PM | #4 |
Check the VIN for sure, but the reason why its titled as a C10 might just be as simple as that's what the fender badge says. My '71 is technically a K20, but the fender badge says C/20. I don't believe the K badges started until at least '73.
1971 Chevy K20 350/SM465/NP205 |
12-10-2013, 05:07 PM | #5 |
Proprietor of Dale's Corner
Lets see the Vin and pics of where the mirror is mounted I believe the mirror mount on a 71 is raised. Might be a 72 with earlier mirror installed
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
12-10-2013, 05:14 PM | #6 |
This all makes sense. Didn't know about the badges all being C-series until '73, and I guess I was mistaken on the K-series Cheyenne designation. I can't remember the VIN off the top of my head - will have to look tonight. I know the cab VIN matches the title.
Where's the VIN on the frame? Will have to see if it matches the cab. The mirror is mounted to the ceiling just above the windshield with the stock '71 mount, as opposed to glued to the windshield like later GM products. The other clue is the door panels. Not sure Chevy changed much beyond that anyway from 71-72, so if it is a cab change, someone effectively made it a '71! |
12-10-2013, 05:23 PM | #7 |
20' Daredevil (Ret)
That's correct as to pickups, but if I'm not mistaken, Blazers wore K5 badges prior to '73. Welcome to the board, BTW. Nice-looking truck!
12-10-2013, 05:25 PM | #8 |
Just to expand on Stockers statement K5 badges were used on the 2wd blazer as well..
12-10-2013, 05:36 PM | #9 |
Thanks!
Now that's not confusing... good job GM! I wonder why. I've given this truck the closest inspection I'm qualified to do - now it's off to the shop to get the pros' opinions. Lucky for me they're only two blocks away. If they like what they see, we might be headed for an LS swap, make this thing into a sweet daily driver... sorry, carb purists! |
12-10-2013, 05:37 PM | #10 | |
Simple? What's simple?
As for the frame VIN, it's behind the steering gear box, though it's often tough or impossible to read. Does the VIN start with C or K? My '69 is titled with the model as "CST10", but the VIN on the title (matches the cab) starts with K. I purchased it from the original owner so I know it is correct.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
12-10-2013, 05:49 PM | #11 |
I'll check the vent window screw, good info! Thanks for the VIN location, I'll check it - assuming, as you indicated, it's not obscured/obliterated by 40+ years of use. Honestly can't remember the VIN 100%, but I want to say it actually begins with "CKE". Will look tonight.
12-10-2013, 05:53 PM | #12 |
CKE would make it a 4wd truck
12-10-2013, 06:07 PM | #13 | |
Around here the ladies at the Secretary of State don't know much about cars. For example, my '65 GTO is titled as a '65 Lemans. I imagine that's pretty universal. Because.....Marketing! Marketing can put whatever they want on the side of the truck without regard to reality. Whatever they think sounds "cool" is close enough. That's why trucks can go from C20 to C200 to C2500 mysteriously from one model year to the next. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-10-2013, 06:25 PM | #14 |
In which case, what's it considered, C-series or K-series? It doesn't really matter - the truck is sweet, the 4x4 works fine (had to drive it home over Wolf Creek Pass in whiteout conditions) - but I'm just curious what the designations designated. Did Chevy make a model with a VIN that started with C and had factory 4x4? Or if the VIN begins with C, does that mean 4x4 must be an aftermarket conversion?
12-10-2013, 06:37 PM | #15 |
My Vin starts out CKE24S and this is how I think it works (I've read some conflicting stuff) C= Chevrolet K= 4x4 E= V8 2= 3/4 ton 4= pick up (cab w/bed) S= St. Louis
12-10-2013, 06:41 PM | #16 |
Okay, so perhaps 2wd C10 VINs begin with "CC" - Chevrolet, 2wd, so on. That makes sense. Thanks!
12-10-2013, 06:48 PM | #17 |
For 1972 trucks http://www.lov2xlr8.no/brochures/che...v/bilder/9.jpg
For 1971 trucks http://www.lov2xlr8.no/brochures/che.../bilder/10.jpg
Trueman |
12-10-2013, 06:50 PM | #18 |
it does get confusing, my 67 4x4 starts with KS, I was thinking about that when I said 4x4's started with K, brain fart or getting old can't remember
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
12-10-2013, 07:00 PM | #19 |
1971 KS=4x4 6cyl truck and a KE= 8cyl truck same in 1972.
The CS =6cyl truck and a CE=6cyl truck from 1/2 to 1 ton from what I see from looking at the GM Vehicle Information Kits http://www.gmheritagecenter.com/gm-h...tion-kits.html The series of GM trucks 10-20-30 trucks equate to 1/2 ton-3/4 ton and a 1 ton. K= 4x4 the S is a 6cyl the E= 8cyd . C= 2 wheel rear drive with the S is a 6cyl the E= 8cyd .
Trueman Last edited by 463; 12-10-2013 at 07:08 PM. |
12-10-2013, 09:11 PM | #20 |
Congrats on the VERY nice truck!
Here's the spec sheet for the 72: http://www.oldride.com/library/1972_chevrolet_c10.html |
12-10-2013, 10:47 PM | #21 | |
12-10-2013, 10:57 PM | #22 | |
12-10-2013, 11:06 PM | #23 |
Thanks for the link! That's super-interesting - because my VIN breaks down as a Chevy, 4x4, V8, 1/2 ton (all correct), 1972 MY, and Baltimore-made. Which is curious, because the cab-mounted VIN indicates '72, but the door panels, mirror location, and absence of door panel screws under the vent windows indicate '71.
It's a mystery! Who knows what's happened to this truck in the last 40 years! |
12-10-2013, 11:09 PM | #24 |
Vin Decoder
Frame partial VIN
CHEVY/GMC VIN DECODERS |
12-10-2013, 11:22 PM | #25 |
That decoder is easier to use - but my results are the same. At least it's consistent!
