Old 12-10-2013, 09:57 PM   #1
Billett
Billett's Avatar
Tow/Haul mode
I've seen a few threads on the tow/haul mode of a truck pcm bring converted to a race style tune instead. When i asked my tuner about this he said that the factory computer cannot support that. Can anyone shed some light on this or should i be looking for a new tuner. This is the same guy who said that he could not change the output voltage on the tech signal, when I've been told that is also possible. These guys have a great record in the Corvette community but I'm starting to wonder if they are right for my build...
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 12-10-2013, 10:33 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Tow/Haul mode
What ECM and transmission do you have? I know you can do that on a E38 ECM and the 6L series transmissions. On the older ECMs I think you have to incorporate the BCM to use the that function.
Edit: Just saw the 4L80 in your signature. You will probably have to incorporate a BCM to make it work. PM LS1Nova, I think he's done it.
Edit 2: When you say "tune", I think you are referring to making the shift points of the transmission "sharper".
Hart_Rod is offline   Reply With Quote
Old 12-10-2013, 10:38 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Tow/Haul mode
I don't think it supports a completely different set of tune parameters...just changes transmission related like shift points, firmness, downshifts, etc.?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-10-2013, 10:52 PM   #4
Billett
Billett's Avatar
Re: Tow/Haul mode
I realize it is just transmission related but tune is easier to type than transmission parameters. And yeah its an 03 engine and a 95 Trans.
Will
2024 Toyota Sienna
Old 12-10-2013, 10:59 PM   #5
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Tow/Haul mode
Frost tuning was offering a dual flash PCM, push a button and a whole new tune. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 12-10-2013, 11:06 PM   #6
Billett
Billett's Avatar
Re: Tow/Haul mode
Don't really want a completely different tune. I mean it would be awesome, but I was really just looking for the tow/haul mode change. I was under the impression that it was possible with these models, but if it isn't at least I feel more comfortable with my tuner.
Will
2024 Toyota Sienna
Old 12-11-2013, 02:35 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Tow/Haul mode
Its called "Performance Mode" in versions of HP tuners, and modifies shift points and tcc lockup changes and tq management (which you may need to re-edit because tq management does weird stuff)
There is an ecm pin where the tow button would wire in, which I think is pin 71 on the GenIII from going over threads.
As for on the newer stuff; its a bit harder to figure out. While there is still a tow haul mode, because of the BCM and TCM, what it does confuses me. There is still a modified shift table, but it also has stuff like engine braking, softened downshifts while loaded, and the Tu/Td functions seen on the Vette's.
oh and the tuner kinda sounds like a knobshine, but what do you mean by "Tech output"? Do you mean tach output, like for hooking up different tachometers? Its called tach output resolution, and yes, it can be changed (its not like changing a voltage number, but which mode/number of cylinders it uses as a tach reference). You can use a pullup in the circuit to get around this issue. Look at the LS2 w/ conventional Tach thread.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-11-2013, 10:49 AM   #8
Billett
Billett's Avatar
Re: Tow/Haul mode
Yeah I did mean tach, typed it up on my phone so it must have "corrected" it. Tried the pull up mod with several different kinds of resistors and none worked. I went with the 680ohm suggested by lt1tech all the way up to the 10k ohm suggested by the guy I called at autometer, and everything in between. The only thing I can say is that I only tried 1/4 watt and not 1/2 watt resistors. Still, like you said also, it can be changed, but the tuner I talked to said it can't be...
As far as the performance mode, I know what it does at least in the early models, just wasn't sure if it was possible on my engine/trans combo or not because of what the tuner said. There isn't much information about it aside from pin 71 like you mentioned. In later model ecms I believe its a 50-something pin. What I have read a few places, and Hart Rod said, that a bcm is necessary for the tow/haul mode. I actually have a spare one, but that is a lot of wiring to do for just the tow/haul button. Can anyone shed light on that? All I see are a lot of posts on the ls1 forum about connecting pin 71, but nothing as far as a swap goes.
Will
2024 Toyota Sienna
Old 12-11-2013, 11:39 AM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Tow/Haul mode
All you need to do is have the "tow/haul" parameters enabled in the PCM. It's been awhile since I've been in one of those tunes, but there will be an drop down box for performance mode with 3 options I believe. "Off", "Class 2" (controlled by BCM), or switch. You just wire a switch in that grounds pin 71 on the blue C1 connector.
In the PCM, Performance mode = Tow / Haul. "Tow/Haul" has it's own shift speeds, shift times, shift pressures, kickdown, TCC apply, TCC release, and torque management calibrations.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-11-2013, 11:50 AM   #10
Billett
Billett's Avatar
Re: Tow/Haul mode
Don't have any tuning software myself, but I'm assuming from the .hpt filetype that you're using HPtuners? I'm trying to find out what software they use, and why exactly they think this can't be done, just to clear my confusion about them.
Didn't know there were three settings! Thanks for the info. If they are using HPT I'll be sure to send them that pic and see what they say. They already unlocked the PCM for me and I'd like to stay with them for the tune, but I don't want to wonder about whether I could have had a better job done...
Br3w - thanks for the heads up on the tach resolution too. I knew you could change it but didn't realize it was only a cylinder/mode sort of thing. That changes things a bit. Guess I'll have to spring for the autometer box after all...
Will
2024 Toyota Sienna
Old 12-11-2013, 12:59 PM   #11
Billett
Billett's Avatar
Re: Tow/Haul mode
Mystery solved. Tune shop thought I meant a full second tune as well, not just trans parameters. Guess I really need to be more careful about what I type. I really appreciate all the info on this though, because I really couldn't find as much as I was hoping for, and I like knowing how the ecm works even if I'm not tuning it myself.
Will
2024 Toyota Sienna
Old 12-11-2013, 02:20 PM   #12
Hart_Rod
Hart_Rod's Avatar
Re: Tow/Haul mode
Here's a good thread on setting up the tach:
http://www.hptuners.com/forum/showth...ach-(autometer
Old 12-11-2013, 02:35 PM   #13
Billett
Billett's Avatar
Re: Tow/Haul mode
I'll have to look through as I haven't seen that particular thread before, but I don't have high hopes. I've tried to get this damn thing to work through a lot of different ways...
Will
2024 Toyota Sienna
Old 12-11-2013, 02:43 PM   #14
Hart_Rod
Hart_Rod's Avatar
Re: Tow/Haul mode
Will your tuner send you a copy of your tune? If so, you can email it to me and I can take a look. I did that setup (in the thread) yesterday on mine and it work perfectly.
Old 12-11-2013, 02:45 PM   #15
Billett
Billett's Avatar
Re: Tow/Haul mode
Haven't asked, but I would hope so. It could come in handy diagnosing anything that might come up in the future. Didn't think to ask for it, but I definitely will.
Will
2024 Toyota Sienna
Old 12-11-2013, 03:30 PM   #16
Hart_Rod
Hart_Rod's Avatar
Re: Tow/Haul mode
Here's a write up on how to trigger the tow/haul mode:
http://www.hptuners.com/forum/showth...-Switch-Option
Old 12-11-2013, 03:31 PM   #17
VroomVroom68
Re: Tow/Haul mode
Doesn't it just keep it from shifting it into OD?
VroomVroom68 is offline   Reply With Quote
Old 12-11-2013, 04:08 PM   #18
Wasted Income
Boosted Member
Re: Tow/Haul mode
I don't know how I could have made it any more clear...but here it is again...
Did you get it that time?
Oh, and the trans will shift to OD in tow/haul.
Turbo diesel
Old 12-11-2013, 04:56 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Tow/Haul mode
In an obdI car, like a 94 Tahoe...then yes, pretty much. In reference to anything in the lsx subset...no.
Did you skip the first 3/4 of the page?
Old 12-11-2013, 05:25 PM   #20
Billett
Billett's Avatar
Re: Tow/Haul mode
The guy's new here, cut him a little slack. but....
Will
2024 Toyota Sienna
Old 12-11-2013, 06:43 PM   #21
Hart_Rod
Hart_Rod's Avatar
Re: Tow/Haul mode
Tough crowd...lol!
Old 12-11-2013, 10:18 PM   #22
Wasted Income
Boosted Member
Re: Tow/Haul mode
I hate spending the time to provide accurate and detailed info to only be questioned about it.
Aside from that...
Turbo diesel
Old 12-11-2013, 10:28 PM   #23
Wasted Income
Boosted Member
Re: Tow/Haul mode
Billett, I know you got your issue taken care of, but this might help somebody else who searches for it.
I got back on my tuning laptop, and pulled up the section in EFI Live. I was wrong. There are 4 choices. There is a description of each in the screenshot below.
Turbo diesel
Old 12-11-2013, 10:37 PM   #24
ls1nova71
ls1nova71's Avatar
Re: Tow/Haul mode
I have a tow/haul switch in my truck, but to be honest I never use it. I just hooked it up since I was using the BCM for the other cool features, and it was just one wire and a switch.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-11-2013, 10:39 PM   #25
ls1nova71
ls1nova71's Avatar
Re: Tow/Haul mode
Wasted, any idea what the 'Manual mode' with 2 switches would do? Just wondering.
