Old 12-19-2013, 12:19 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Dash repair
I am looking at an original 2wd Blazer and it has an odd cut to the dash, I'm really not sure why someone would do this. Can this be fixed and how would it be done? Patch panel available?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-19-2013, 01:05 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Dash repair
Post a WTB add inn the parts section and someone out there will have a piece that will fix that. You will need to have it welded in and finished.
Add the same photo to your wanted to buy add.
The alternative is to replace the whole dash section which still requires welding and is a lot more work.
Good luck
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 12-19-2013, 01:22 PM   #3
jaros44sr
jaros44sr's Avatar
Re: Dash repair
Isnt that the ash tray area? Ive got one i wont be using, your welcome to it. Some damage to the radio opening, but otherwise intact.....
Those two holes are just for ashtray bumpers, one looks alittle large
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-19-2013, 01:23 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Dash repair
Teeitup usually has these oem panels for radio repairs.
If your adding air,... I would consider a complete dash swap with a factory air dash.
Keith
Convert to disc brakes.
Old 12-19-2013, 03:53 PM   #5
C10_ustacould
Re: Dash repair
Just trying to get a feel for how much work it will take to finish it up. It will need the dash repaired as well as patches on the bottoms (inside) of each door to have all of the sheet metal solid. After that it will be PB suspension and interior work. Hmmm
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-20-2013, 03:51 AM   #6
Blazerowner
Blazerowner's Avatar
Re: Dash repair
There are aftermarket dash replacements for the stereo being cut. I can't remember who carries them, It may have been lmc or brothers but I know they are made.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 12-20-2013, 09:51 AM   #7
Hart_Rod
Hart_Rod's Avatar
Re: Dash repair
http://www.brotherstrucks.com/prodin...number=DFRP072
Hart_Rod is offline   Reply With Quote
Old 12-21-2013, 02:10 PM   #8
Blazerowner
Re: Dash repair
That's the one. I'm lucky mine was never cut.
Kirk
66 Nova
Old 12-31-2013, 01:38 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Dash repair
Its an easy repair I just wonder what they were thinking when they cut that out?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-31-2013, 02:11 PM   #10
swyfor5
swyfor5's Avatar
Re: Dash repair
Looks like a hole for a CB radio to me. Bad,very bad! It can be fixed fairly easy though.
swyfor5 is offline   Reply With Quote
