Old 10-26-2013, 12:11 AM   #1
1985_C10
1985_C10's Avatar
headlights
i want to get some brighter headlights on my 85'. can anyone give me some ideas on what to get? maybe even an hid kit. i dont want to be spending a lot of money on it though. thanks.
1985_C10 is offline   Reply With Quote
Old 10-26-2013, 12:31 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: headlights
Don't get an hid kit if your not going to spend tho money setting them up right
What you can do is buy relays and sylvaina halogens and that will get a nice increase in output, that alone is usually enough for everyone
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-26-2013, 12:37 AM   #3
1985_C10
1985_C10's Avatar
Re: headlights
sylvania sells silverstar and xtra vision lights for my truck. which ones are brighter?
Old 10-26-2013, 12:42 AM   #4
1985_C10
1985_C10's Avatar
Re: headlights
and what kind of relays do i need?
Old 10-26-2013, 01:22 AM   #5
83GMCK2500
Re: headlights
We have a vendor here that has a really nice kit already assembled and ready to rock and roll. 1973-1987 Chevy & GMC Dual Headlight HD Headlight Harness
After that a quality bulb to go with it. There are a few options. To answer your other question first Silverstars are brighter than extra vision.
HIDs should be done with a fairly high level of care and detail. There are some great threads here... First Second
Another option are H4 conversion lenses. For your upper Hi/Low lens, and your lower High lens. Those will allow you to run H4 & H1 capsule bulbs of which there are a LOT more options than sealed beams. The Sylvania/Osram Night Breaker and Philips Xtreme Power (XP) are the first two that come to mind that perform very very well. Built for go, not show. Though I think Philips phased some of them out, might be hard to find.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 10-26-2013, 03:01 AM   #6
andrewmp6
Re: headlights
Unless you live in the sticks or go off road you don't need hids,Honestly a good set of h4 lights with the relay harness will be more then enough light.On the h4 lights stick to big name brands like hella ipf delta.Another thing for night driving get led dash lights you will be able to read the gauges easy with them.
andrewmp6 is offline   Reply With Quote
Old 10-26-2013, 03:02 AM   #7
1985_C10
1985_C10's Avatar
Re: headlights
is there anywhere else besides theretrofitsource.com that sells projectors for any cheaper?
Old 10-26-2013, 03:04 AM   #8
1985_C10
1985_C10's Avatar
Re: headlights
classic industries sells some h4 lenses for about 22 bucks a piece. do you think those would be any good?
Old 10-26-2013, 03:13 AM   #9
andrewmp6
Re: headlights
Just depends what brand they are and how the reflector is made.The cheaper brands will have a terrible light pattern and or fog up over time.Look around online for hella brand 4x6 ebay amazon etc etc see how cheap you can get them.
Old 10-26-2013, 03:40 AM   #10
1985_C10
1985_C10's Avatar
Re: headlights
what about the autopal h4 lenses? they are made of metal and glass instead of plastic.
Old 10-26-2013, 04:02 AM   #11
andrewmp6
Re: headlights
If they are e code get them,Basicly e code means euro and they are made a little better vs the dot aka us versions.
Old 10-26-2013, 04:26 AM   #12
83GMCK2500
Re: headlights
See that blue text in my earlier post? The ones that say Low and High beams? Those link to the E-Code Hellas that andrew just mentioned...they are available on amazon/ebay/etc, just look for those key terms. I've compared the Autopal and the Hella, one in each hand...yes the Autopal are metal and glass, but the quality just isn't there compared to Hella or Bosch.
Devin
New Daily, the '96
Old 10-26-2013, 09:00 AM   #13
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: headlights
I have the cucvs and they come with perhaps the dimmest headlights made.. I went out and got the Sylvania silverstar Ultra jobbies and they work great even in the woods they are a tad pricey tho compared to what I remember paying for a headlight a few years back
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-26-2013, 09:19 AM   #14
Skunksmash
Skunksmash's Avatar
Re: headlights
Regardless of what bulb setup you choose, these are the relay's you'll want to use. The fuse is built into the relay, which will eliminate the need for those in-line fuses. Saves a buck, and cleans up a little unnecessary wiring. Used them on my H4 conversion.
HELLA 003530041 12V/25 Amp SPST Mini ISO Relay... HELLA 003530041 12V/25 Amp SPST Mini ISO Relay...
I was going to go HID but decided not to for now, due to more complexity and higher cost. Probably will later, since now everything to support them is already installed. You could do the same and just make the easy switch to HID when you've got more money. I can say the H4's are a night and day difference over the stock junk, though.
Skunksmash is offline   Reply With Quote
Old 10-26-2013, 09:42 AM   #15
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: headlights
I recommend Sylvania Silverstar they are bolt in option, and make a huge difference. I have had mine in for about 9 years now and still going strong.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 10-26-2013, 09:52 AM   #16
bojak
bojak's Avatar
Re: headlights
Relays and the sylvania's are the best bang for the buck. You could probably just do relays and not believe how much better it is. That is if low bucks is the goal. If " what's the cheapest projector setup that gives awesome results, with modern looks, at the best price" is your goal, then I have no clue. stay classy
bojak is offline   Reply With Quote
Old 10-26-2013, 02:45 PM   #17
meatwagon83
meatwagon83's Avatar
Re: headlights
i have silverstars and relays in my headlight harness, no kidding i can see more than 1/2 a mile with my brights on, there is no need to get too fancy, i have about $115 in mine, including $100 dollars worth of headlights
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 10-26-2013, 02:57 PM   #18
piecesparts
Parts and more parts
piecesparts's Avatar
Re: headlights
I tried Silverstars and YES, they are an improvement, but for me not enough to see the deer that are out there. I went to a different path and purchased a set of lights from Vision X lighting wholesale. http://www.visionxwholesale.com/ This gave me a metal light recepticle to put updated light bulbs into. I chose to go full bore and put in 80/100 watt bulbs with a wiring harness to take the wattage load off of my headlight switch and now I see everything quite well. These light housings have internal covers for the bulb to keep the light from blinding oncoming drivers. I have the four headlight bulb set on my truck and I replaced all of them.
Frank
piecesparts is offline   Reply With Quote
Old 10-26-2013, 08:24 PM   #19
1985_C10
1985_C10's Avatar
Re: headlights
So to do an h4 conversion, what all do i need to buy and how do i hook it all up?
Old 10-27-2013, 01:44 AM   #20
83GMCK2500
Re: headlights
You do have the dual 6x4 headlamps, correct? Check out that lighting upgrade harness I posted earlier, it is strongly advisable to either build one of those or buy something similar.
Harness instructions to BUILD YOUR OWN: HERE
Upgraded Harness from LMC
VH Coachworks
Upper/Low-&-High Beam Lens Kit (both lenses, L/R): Amazon (link) Amazon (link)Lower/High Beam Lens Kit (both lenses, L/R): Amazon (link) Amazon (link)&
your choice of H4 (low/high) and H1 (high) capsules/bulbs.
Sylvania Silverstar - H4: 64193SV2 | H1: 64150SV2
Osram Night Breaker Plus - H4: 64193NBP | H1: 64150NBP
PIAA Night Tech - H4: 10704 | H1: 10701
Google those part numbers, search them in ebay or amazon, they're sold about everywhere.
Devin
New Daily, the '96
Old 10-28-2013, 11:33 AM   #21
4x4toy
Re: headlights
http://www.danielsternlighting.com/
Some real good info on upgrading driving lights
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 10-28-2013, 09:47 PM   #22
anubisani
anubisani's Avatar
Re: headlights
THESE ARE WHAT I JUST BOUGHT THEY ARE AWESOME AND REALLY BRIGHT oops sorry for yelling an minimal strain on headlight switch.
http://www.ebay.com/itm/161102555516...84.m1436.l2649
anubisani is offline   Reply With Quote
Old 10-29-2013, 04:19 AM   #23
Tuff 1986
Tuff 1986's Avatar
Re: headlights
Sorry for jumping in here but while on the subject... I have some sylvaina halogens on my truck.. Can you help me out.. What type of relays would I need for them.. My truck is single head lamp..
Will I ever finish my 1986 stepper..
Tuff 1986 is offline   Reply With Quote
Old 10-29-2013, 06:26 AM   #24
INSIDIOUS '86
Re: headlights
Bosch style relays are all you need
Old 10-29-2013, 11:06 AM   #25
Tuff 1986
Tuff 1986's Avatar
Re: headlights
Ok, thanks
