Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-25-2013, 10:01 AM   #1
MashTheGas 72
Old Grey Haired Man wants some boom!
I am almost 50 but I still like my tunes, and yes BOOM. I wanted to know the best and less expensive way to go. I will need an Amp, stereo, and subs, speakers.
1st would it be best to just cut out my dash to accommodate a new unit.
2nd has anyone been able to mount subs behind the seat with gas tank still in.
3rd where is the best place to mount my amp, Under seat?
4th I was looking on amazon and found a woofer setup that looked like it would go under the seat.
5th Has anyone installed a stereo with full DVD screen.
Pictures would be awesome of your setup. Thanks a lot for your advice in advance.
72 GMC 1/2 Ton
MashTheGas 72 is offline   Reply With Quote
Old 12-25-2013, 04:39 PM   #2
Red4x4
Re: Old Grey Haired Man wants some boom!
Good Question, I will be checking back to see some peoples answers.
Merry Christmas Everyone!
Red4x4 is offline   Reply With Quote
Old 12-25-2013, 04:50 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Old Grey Haired Man wants some boom!
I know they make the under the seat boxes but the gas tank area is pretty small. You might could do something your self. I built my own double sub box behind the seat but the tank is gone.
I would by a single din unit if going in the dash and if you wanted a full navigation one build a center console to install it. I have both amps under the seat in my 71.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-25-2013, 06:14 PM   #4
MashTheGas 72
Great info keep it coming.
72 GMC 1/2 Ton
Old 12-25-2013, 06:44 PM   #5
Ironhorse
Ironhorse's Avatar
I moved my in-cab tank to under the bed and got a set of corner speaker brackets from board member bigblock73 (Jeff) and mounted Pioneer tri-axial 150watt 6x9's there and had a stereo shop mount a pair of Polk 5" 100 watt dual cone under the dash. These are hooked to a Sanyo FXCD-500am/fm/cd/cassette single DIN unit. That is mounted under my dash in a marine weather proof enclosue. Attached a pic here. In the dash I have an original FM truck AM/FM I bought at a swap meet and had re-furbished. Both radios run off the same fender mount antenna using a splitter lead. Don't do Ipod or MP3, too much old school for that.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 12-25-2013, 07:02 PM   #6
MashTheGas 72
That's great I happen to have one of those closures I never used on my boat. Great idea.
72 GMC 1/2 Ton
Old 12-26-2013, 09:24 PM   #7
MashTheGas 72
I was looking on Amazon at the shallow woofer amp combo's. The dimensions measure thin enough to go under my seat. Has anyone tried one of these and does anyone know a good brand. I noticed Boss,Pyle,Soundstream, Kenwood has one.
72 GMC 1/2 Ton
Old 12-26-2013, 10:50 PM   #8
ca90ss
I'd stay away from anything from Boss, Pyle or newer Soundstream. Of the four I'd pick the Kenwood.
ca90ss is offline   Reply With Quote
Old 12-26-2013, 10:54 PM   #9
MashTheGas 72
That's what I was leaning towards except the amp only has 150 watts. But should be plenty for me,
72 GMC 1/2 Ton
Old 12-26-2013, 11:05 PM   #10
ca90ss
If it were me and I had to put the sub under the seat I'd probably go with something like this and build my own box for it.
http://www.parts-express.com/peerles...ofer--264-1105
Old 12-28-2013, 09:13 PM   #11
69sinker
69sinker's Avatar
Just made this console and installed a Kenwood DVD / Bluetooth stereo. Rear corner mounted 6x9's, dome tweeters mounted in corners by visors and basslink powered sub behind bucket seats. All speakers are Infinity.
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 12-28-2013, 09:40 PM   #12
MashTheGas 72
Now that's an awesome idea. What did you do about your heater floor exit.
72 GMC 1/2 Ton
Old 12-28-2013, 09:47 PM   #13
69sinker
69sinker's Avatar
The sides (at the back) are cut at an angle and I placed a plate in the back to divert the heat to each side and keep the heat away from the stereo.
Old 12-28-2013, 09:51 PM   #14
MashTheGas 72
I thought you probably did something like that. This time of year is a good time to try it. You built the box yourself? Is it made of aluminium?
72 GMC 1/2 Ton
Old 12-28-2013, 09:59 PM   #15
69sinker
69sinker's Avatar
Yes, it's 1/4 aluminum and 1/4 tinted plexiglass that's painted black on the backside to keep from seeing through it. Ordered the ss cupholders on ebay. I've got about 10 hours in it.
Old 01-03-2014, 02:05 PM   #16
Low Elco
If you ipod/phone, etc, these are cool-
Amazon.com: KICKER Amplified Controller for iPod:... Amazon.com: KICKER Amplified Controller for iPod:...
Low Elco is offline   Reply With Quote
Old 01-04-2014, 10:06 AM   #17
MashTheGas 72
I think I've decided it's time to go ahead and do the under bed tank Conversion. Once I do that then I will have better options! I really appreciate every bodies input it was very helpful. Thanks. Lyn
72 GMC 1/2 Ton
Old 01-04-2014, 08:57 PM   #18
_Ogre
_Ogre's Avatar
once you relocate the tank; look at my build. 2 amps, a single 10 sub and my battery reside in the gas tank slot.
and yes on question 1. single din head units will be around for years. cut the dash.
there are a couple of very nice 67-72 retrofits in this ''truck audio'' section.
shop air compressor timer
Old 01-04-2014, 09:58 PM   #19
MashTheGas 72
That's an awesome build! Thanks for the ideas.
72 GMC 1/2 Ton
Old 01-05-2014, 01:22 PM   #20
_Ogre
_Ogre's Avatar
thanks. while mine is a 58 the sub/amp/battery enclosure could easily be built for a 67 truck.
Old 01-06-2014, 05:37 PM   #21
maxxxy
maxxxy's Avatar
Obviously the more money you can put into it, the better quality you will get. The more custom you're willing to get, the better everything will fit. I think a very good basic setup would be 4- 5.25"or 6.5" speakers and a 200-300 watt rms subwoofer. Great for all around listening, and fairly cost effective option. I suggest on a truck that old, replacing the factory audio wiring would be most beneficial. Wiring from Knu Konceptz is fantastic for the price. This might seem overwhelming, but its really only 2 wires per speaker, and will increase audio quality tenfold as well as lower risk of wire fire. If you have any questions, feel free to pm me, I can help you find a perfect setup if I know a little more about your tastes and budget and applications.
-Max
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 01-06-2014, 05:54 PM   #22
MashTheGas 72
-Max
I will defiantely do that. Thank you for the help.
72 GMC 1/2 Ton
