Old 12-26-2013, 02:58 PM   #1
jd21476
jd21476's Avatar
Power steering squeal!!
My power steering works great and does not leak but when I hit the ends of the range it lets out a loud squeal. Now I know enough not to keep it pinned all the way as that is bad for the pump but my new cars do not squeal when I hit the end. Any ideas?
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 12-26-2013, 03:07 PM   #2
buddy_1
buddy_1's Avatar
Re: Power steering squeal!!
Sounds like the belts need to be adjusted. It is slipping when you load it up. Buddy
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 12-26-2013, 03:09 PM   #3
jd21476
jd21476's Avatar
I recently tightened the belts but maybe it just needs some new ones.
1973 Chevy K20
Old 12-27-2013, 02:16 AM   #4
78trk
The belts are probably loose. loosen the air conditioning belt then tighten the power steering belt. then tighten the air conditioning belt. If the pulleys are worn in the groves you may have to replace them to get a tight belt that will not loosen up right away.
78trk is offline   Reply With Quote
Old 12-27-2013, 11:06 AM   #5
jd21476
jd21476's Avatar
Ha!!! Thats assuming I have A/C...which I dont
1973 Chevy K20
Old 12-27-2013, 11:14 AM   #6
tucsonjwt
Try adding some power steering additive to the pump. I replaced the belts and pump in my truck and about one year later the pump started to squeal. A little pump additive/conditioner eliminated the squeal, which was also at the end of the steering range on my truck. It has been quiet for about 4 years now.
If that does not work and you need a new pump I would recommend getting an AC Delco pump - it will likely still be made in China but it should be made to GM specifications. Just shop the OEM online sellers and it won't cost much more than an aftermarket pump.
tucsonjwt is offline   Reply With Quote
Old 12-29-2013, 12:45 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Do you have headers?or manifolds?
are your pullys lined up?
maybe the pump is new/defective or old/dying
you didn't say,and no pics
but if this piece is missing good luck getting it tight
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-29-2013, 07:14 PM   #8
jd21476
jd21476's Avatar
I've got that piece so getting it tight is not an issue.
1973 Chevy K20
