Old 12-30-2013, 08:31 PM   #1
Blackpony
Blackpony's Avatar
hedman swap headers
Anyone use the hedman 45660 swap headers? I just ordered a set today, hoping they fit and work pretty well. Once I know they work good and such I plan to have my local powdercoater ceramic coat them. He is much cheaper then the difference they want to buy them already coated, so saves a little money too..
Blackpony is offline   Reply With Quote
Old 12-30-2013, 10:01 PM   #2
p3ug
Re: hedman swap headers
I was looking at these too. Keep us updated when they come in.
p3ug is offline   Reply With Quote
Old 12-30-2013, 10:34 PM   #3
Blackpony
Blackpony's Avatar
will do, hopefully they get here before the weekend, if so then I plan to get them installed and get to the muffler shop to have the exhaust hooked back up.
Old 01-08-2014, 08:23 PM   #4
p3ug
Did you have a chance to get these in ?
Old 01-09-2014, 11:52 PM   #5
Blackpony
Blackpony's Avatar
Yes I did. They fit fantastic! Tons of room all around, they slipped right in. Here are a few dark photos I'll try and grab a few better ones tomorrow.
Old 01-10-2014, 06:49 AM   #6
p3ug
They look good. Do they hang below the frame at all? I think these are what I'm going to go with also.
Old 01-10-2014, 01:47 PM   #7
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
look like a good alternative to the DT's.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-10-2014, 03:43 PM   #8
Blackpony
Blackpony's Avatar
No they are above the frame. It's kind of a tight bend after the collector to keep it that way but the muffler shop did a great job keeping it tucked. Anyone looking for swap headers I highly suggest these!
Old 01-11-2014, 05:13 PM   #9
kamikazekyle05
kamikazekyle05's Avatar
What engine mounts are you using?
kamikazekyle05 is offline   Reply With Quote
Old 01-11-2014, 05:31 PM   #10
crazy longhorn
Fabricate till you "puke"
Very nice fit on that "square body" For the 67-72 crowd, my bet is that they will not fit with stock mounts/stands....swap to the 73-up mounts/stands, & I will bet that you are good to go? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-12-2014, 03:35 AM   #11
Blackpony
Blackpony's Avatar
I bought some adapter plates off eBay, then used the factory mounts from there. Just redrilled the frame for the trans crossmember and the factory shifter linkages all hooked right up.
Old 01-12-2014, 04:44 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
They look good, and I'm wondering how the fit flipped (turbo style).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-10-2014, 09:56 PM   #13
bdydrppup
do you think they would clear with a 2.5" z? so raising the motor 2.5".I tried the schoenfeld long tubes and they hit my control arm on the driver side and floor board on the passenger side.
bdydrppup is offline   Reply With Quote
Old 02-11-2014, 10:29 PM   #14
Blackpony
Blackpony's Avatar
I doubt they will fit with a z. I'll try and get a few pics tomorrow if isn't raining.
Old 02-13-2014, 03:32 PM   #15
sama lama
What size primary tubes are they
sama lama is offline   Reply With Quote
Old 02-14-2014, 12:18 AM   #16
Blackpony
Blackpony's Avatar
They are 1 3/4 primary 3'' ball and socket collectors.
Old 02-14-2014, 02:43 AM   #17
stevenbear72
stevenbear72's Avatar
How much were these headers sir?
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 02-14-2014, 06:24 AM   #18
DjS71
Summit has them @ $350
Here's a link to the Hedman site with a bunch of different options it seems. Mid length, long tube, primaries in 1-3/4, 1-7/8, stepped 1-3/4 to 1-7/8 stepped 1-7/8 to 2 and 2". Uncoated, black & silver.
All listed as "Chevrolet C10 Pickup 1967 to 1974 Liter: 4.8, 5.3, 6.0"
Notes for my vehicle for instance are:
BlockType V
Cylinder 8
Cylinder Head OHV
Aspiration Naturally Aspirated
Fuel Type GAS
Vehicle 1971 Chevrolet C10 Pickup
Footnotes (M35) Clears the factory OEM A/C box, power steering box, and power brakes.
(M14) In some installations starter, valve cover, and/or spark plugs may need to be removed.
(M34) Mid-length Hedders have a weld-on ball and socket type collectors with O2 sensor bungs.
(M29) NO transmission tunnel modifications required.
(M21) Designed for use with a GM LH-8 oil pan.
(M13) If using a 4L80 transmission, the bell housing tabs must be trimmed for hedder clearance.
(M11) Designed for use with T-56, 4L60E, 4L65E, 4L80E transmissions.
(M7) Hedders are designed around a floor shifter linkage. Column shift linkage may require modifications for clearance.
(M24) NO notching of the frame is required when using the 98-02 Camaro/Firebird A/C compressor and alternator.
Manual Transmission - Floor Yes
Auto Transmission - Floor Yes
Manual Transmission - Column No
Drivetrain 2WD
Air Conditioning Yes
Power Steering Yes
Auto Transmission - Column No
Engine Family SB CHEVY Gen III/IV (LS engines)
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 02-14-2014, 12:36 PM   #19
littlevictories
I wonder how these would fit in the 60-66 rigs
littlevictories is offline   Reply With Quote
Old 02-14-2014, 01:00 PM   #20
jamesjones
Freakin Awesome!
jamesjones's Avatar
The long tube 67+ headers look like they might fit my setup...hmmm...
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 10-23-2014, 10:38 PM   #21
slowcpe
slowcpe's Avatar
Resurrecting this thread. Anybody tried the long tubes? Thinking about running the 1 7/8".
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 10-24-2014, 08:38 AM   #22
Mayfield
I'm running them on mine. Square body though. Only issue, I had to slightly clearance the frame on the drivers side. One primary tube was touching the frame, with a minutes work of the grinder, it was taken care of.
Mayfield is offline   Reply With Quote
