Old 01-02-2014, 12:34 PM   #1
ubtripn
ubtripn's Avatar
700R4 makiing strange noise when I put it in park
The problem is intermittent, occurring once every 20 or so times I put my truck in park. It makes a sound similar to a playing card in a bicycle spokes. It lasts about a second or two and winds down. I am fully stopped when this happens. Any ideas?
ubtripn is offline   Reply With Quote
Old 01-02-2014, 12:37 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 700R4 makiing strange noise when I put it in park
Is it fast, almost a buzzing?
It could be the pressure regulator valve shuttling. Usually not a problem except for the noise. There is a fix by grinding this land off
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-02-2014, 12:41 PM   #3
ubtripn
ubtripn's Avatar
Pretty fast, kind of like putting a screwdriver on the flywheel until it stops or winds down.
Old 01-02-2014, 01:16 PM   #4
cool68
as the doctor says when you go into his office and you tell him "my arm hurts when I lift it" Doc says "then don't lift your arm"
cool68 is offline   Reply With Quote
Old 01-02-2014, 01:44 PM   #5
ubtripn
ubtripn's Avatar
so..don't put it in park? =)
Old 01-02-2014, 01:45 PM   #6
ubtripn
ubtripn's Avatar
I am about to drop a new engine in anyway, I was wondering if the torque converter could cause this?
Old 01-02-2014, 02:56 PM   #7
Longhorn 70
Longhorn 70's Avatar
Parking pawl? May have gotten bent from placing in park before completely stopped?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-02-2014, 03:03 PM   #8
ubtripn
ubtripn's Avatar
Thank you! I have no idea how to check that. Any suggestions?
Old 01-02-2014, 03:28 PM   #9
Longhorn 70
First I'd check to make sure the linkage is adjusted.
Old 01-02-2014, 03:28 PM   #10
ubtripn
ubtripn's Avatar
ok, will do and thanks!
Old 01-02-2014, 06:10 PM   #11
hugger6933
X2 on parking pawl. to check to see if the linkage may be the problem [and it mostly is on this problem]take the shifter out of the trans hole and if it moves ever so slightly it is the problem. You will be able to tell it will like fall in to park once the linkage is unhooked
hugger6933 is offline   Reply With Quote
Old 01-02-2014, 06:40 PM   #12
ubtripn
ubtripn's Avatar
Sounds good, so it may not be an expensive issue then,thats good news.
Old 01-02-2014, 06:45 PM   #13
Bigdav160
Bigdav160's Avatar
If the truck is not moving the parking pawl cannot make noise. The gear is integral part of the output ring gear.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 01-02-2014, 07:02 PM   #14
ubtripn
ubtripn's Avatar
My fear was a bad torque converter, as I said I am about to install a new engine and my radiator is new so I did not want to send metal shavings through all the passages.
