01-02-2014, 08:19 PM | #1 |
Rear shock relocation
My shocks got in the way of my exhaust routing, so I removed them built the exhaust and know it's time to relocate the shocks, I'm thinking about to the rear of the diff. Anyone have any pros or cons?
01-02-2014, 08:34 PM | #2 |
Re: Rear shock relocation
I believe the No Limit relocation kit uses that approximate point. I've heard great things about them. They have a thread in the suspension forum.
http://67-72chevytrucks.com/vboard/s...d.php?t=444928
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
01-02-2014, 09:24 PM | #3 | |
01-02-2014, 09:49 PM | #4 |
Info note : the 60-62 frame had them outside leaned back like that. Sure there are pictures on my build thread.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-02-2014, 11:45 PM | #5 |
Have them like that on several 4x4 rigs and work fine.
Make sure you compress the rear and load the axle into the notch then measure the compressed length and set up your brackets accordingly. You don't want the shock to bottom out before the axle does.
GOD BLESS AMERICA! |
01-03-2014, 03:16 AM | #6 |
Here's the way member Frizzle Fry did it and I did the same with mine. Almost what you're talking about.
http://67-72chevytrucks.com/vboard/s...postid=4730005
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
01-03-2014, 10:20 AM | #7 |
Thanks for the input. All get going on making new brackets today.
