Old 01-05-2014, 11:46 AM   #1
A-B Slinger
A-B Slinger's Avatar
Steel Wheels / 8 X 15's
I acquired 4 NOS hubcaps for my 80 K10 a while back and now my search for some 8 X 15 steel wheels has become some what harder than anticipated. Any suggestions on a source for these would be appreciated.
A-B Slinger is offline   Reply With Quote
Old 01-05-2014, 12:54 PM   #2
54blackhornet
54blackhornet's Avatar
Re: Steel Wheels / 8 X 15's
Good Luck ! I have been looking for a set myself for a long time with little success ? I live in a rural area and stop at farms and ranches and ask if they have an old tire and wheel pile I can look over, still no luck yet but I won't give up....
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-05-2014, 12:56 PM   #3
54blackhornet
Just noticed you are in Asotin ? WOW , I drive thru on my way to Lewiston all the time ? Are you in Town or outside ? We should get together, I have a 71 K-10 I am building ......Happy New Year !
71 C-20
07 Magnum RT AWD
Old 01-06-2014, 09:05 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
The military Blazers (M1009) have 15 x 8 steel wheels. Go to a military swap meet or scrap yard.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 01-07-2014, 10:55 AM   #5
diver
hi men,have you tried wheel vintques
diver is offline   Reply With Quote
Old 01-07-2014, 10:29 PM   #6
Do they make 6-lug?
Old 01-08-2014, 10:10 AM   #7
diver
yes, summit racing sells them
Old 01-08-2014, 10:39 AM   #8
lahnen
I got lucky and ended up with a set on a truck I bough years ago. almost gave them away until I found out how hard to find they are.
lahnen is offline   Reply With Quote
Old 01-08-2014, 12:04 PM   #9
Summit's search feature sucks! I just tried to check,I selected "Wheels",then Wheel Vintiques, and the only way to narrow the search was dollar value (I'm supposed to know how much they cost before I find if they even sell them?). Fortunately,I know about how much they cost and the amount I chose showed 15 x 8 wheels on the first page. But rather than sort through 255 wheels I'd like to narrow my search. The only option they give is by Make/Model or Make/Engine,which is absolutely worthless for almost all the wheels they sell. They're custom,right? Why not offer search by wheel size?? Duh? I'll try directly from the people who make them.Thanks anyway Summit
Old 01-08-2014, 01:09 PM   #10
61K10
61K10's Avatar
vintques in 6 lug are smoothies, stock caps won't fit. Stockton wheel out here in ca. has them.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-08-2014, 01:42 PM   #11
Southcity
Southcity's Avatar
I was faced with a similar challenge a few months ago for my 66 Suburban, needed 6 lug stockers for front (15x6.5) and 6 lug 15x8's for the rear that also accept the dogdish caps - I scoured CL and eBay everyday. I found that 15x8's come up more regularly on eBay (than the stockers) and shipping is easier and more affordable than if you try to purchase from a CL seller . It's luck of the draw and when they do show up on either CL or eBay they go fast so you have to be diligent and check everyday - good luck!
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 01-08-2014, 02:43 PM   #12
That's what I thought,but I wanted to check if they started making them. Sorry about my earlier rant. I have little tolerance for monster size companies
Old 01-09-2014, 07:23 PM   #13
A-B Slinger
Spoke with Rick at Stockton Wheel today.
Steel , bare , 8 x 15 , 6 lug , half ton , four wheel drive , for factory dog dish hub caps @ 10.125" ID and he says no problem.
$ 125 ea.
Seems like a decent price.
Old 01-09-2014, 07:53 PM   #14
Southcity
Southcity's Avatar
That is a decent price, it really comes down to how quickly you need them and how much you are willing to pay. You can find a used set cheaper but who knows how long that will take. If you pull the trigger on these be sure to keep us updated with pics of your rig once you get them mounted up. What are your plans with these steelies - painted body color? what style dogdish cap are you planning on running? what size/style of tires?
Old 01-10-2014, 10:30 AM   #15
Just curious where you found your hubcaps and,if you not mind me asking,about how much did you pay?
Old 01-15-2014, 02:21 PM   #16
Scott Johnson
Junior Member
Scott Johnson's Avatar
Do you have a part # on the wheels from Stockton?
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 01-15-2014, 04:13 PM   #17
whitedog76
Dexstar wheel has 15x6, 16x6, and 16.5x6.75. They're OE style rims that'll fit factory hubcaps. They're listed for "trailer use" but I'm sure they'r more than stout for truck applications.
I'm sure you need the wide rims, for bigger tires, after all this is the 4x4 section. I thoght I would just throw something out there.
http://www.dexstarwheel.com/products.pdf
whitedog76 is offline   Reply With Quote
Old 01-16-2014, 12:52 PM   #18
A-B Slinger
Rick did not give me a part #. They will build them as needed. Forgot he also needs the back spacing. 3.875" in my case. I will run the typical
33 x 10.5 15's. BFG. All terrain on my factory ralleys and mud terrains on the steel wheels. I will snap a photo of the caps when I get to the shop today.
Old 12-11-2014, 11:13 PM   #19
picklito
Originally Posted by whitedog76 View Post
Dexstar wheel has 15x6, 16x6, and 16.5x6.75. They're OE style rims that'll fit factory hubcaps. They're listed for "trailer use" but I'm sure they'r more than stout for truck applications. http://www.dexstarwheel.com/products.pdf
I've been looking at those Dexstar wheels in 15x6 size. Does anybody know if they'll fit disc brakes?
picklito is offline   Reply With Quote
Old 12-15-2014, 08:20 AM   #20
Most likely yes, since disc brakes have been in use since '71. if they have 4 hubcap nubs you are good to go. The drum brake wheels only have 3 nubs
Old 12-17-2014, 09:43 PM   #21
whitedog76
Dexstar Wheel has a 15x6 and 16x6 steel wheel that you can use a factor hubcap on. Most trailer supply places can get them for you.
