01-06-2014, 02:54 PM | #1 |
Question about trailing arms
I just got mine off and cleaned them up. Its a wonderr they all don't break. Now the split in the middle of them should i seal that. also the piece that is spot welded on has some areas that are pulling apart, can i clean up under them and reweld or not. pics to follow. Thanks nick
01-06-2014, 04:32 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Question about trailing arms
maybe bite the bullet and get some tubular ones, is your truck a driver or a show truck?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-06-2014, 07:03 PM | #3 |
Dd
01-06-2014, 07:28 PM | #4 |
You can run short 1-2" beads down the center seam if there's no significant rust or scaling for peace of mind.
