Old 01-07-2014, 11:25 AM   #1
64tantruck
64tantruck's Avatar
Metric Bolt Help
When I took my truck apart, I labeled every bolt and put them in baggies, in storage.
I have purchased new sheet metal from various places.
The inner fenders came from a friend (new just not used on his project)
Fenders from Goodmark.
Front radiator support from LMC
etc....
These new parts have metric threads. Does anyone know size thread etc..?
Truck is at the body shop and I know that I will need to get this hardware soon.
An thoughts?
Glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 01-07-2014, 12:19 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Metric Bolt Help
I checked a couple of the body bolts I have laying here and looks to me like the equivalent could be a M9x1.5. That is a guess though but should get you close. Lowe's has a decent selection of factory looking bolts in and around that size. I'd grab a couple of samples to see what fits. Its a shame they are switching to metric though.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-07-2014, 01:01 PM   #3
davbowen
davbowen's Avatar
metric equivalent sizes:
#10 screw = 5mm x .8
1/4" = 6mm x .7
5/16" = 8mm x 1.25
3/8" = 10mm x 1.5
1/2' = 12mm x 1.75
9mm screws are not a standard size, although it may be available.
davbowen is offline   Reply With Quote
Old 01-07-2014, 01:19 PM   #4
cg285
places like s&r fasteners (http://www.srfast.com/) and others (aveco, wurth...)should have the correct style capscrews
cg285 is offline   Reply With Quote
Old 01-07-2014, 03:10 PM   #5
64tantruck
64tantruck's Avatar
Well,
I was able to paw thru some boxes of misc bolts and took the one that fits to NAPA
Just got back from NAPA M8-1.25 30mm
napa part number 6641640 a 25 count box was $13.99.
Thanks for the responses.
Glenn
Glenn Korec
Jamesville NY
