Old 01-08-2014, 01:26 PM   #1
Daking19
Carpet kit???????????
im trying to order a carpet kit and they asked if i had og manual trans or automatic. i have recentally purchased the truck and the eng and trans were changed. whats in there now is a floor shift 700r4 automatic. it does have a big hump which makes me think it was a manual out of the factory is there anything else i can check before i order the carpet kit. once again thansk everyone
Daking19 is offline   Reply With Quote
Old 01-08-2014, 04:12 PM   #2
brokestudent
Re: Carpet kit???????????
I am no expert here, but I would say you might be better off to order the automatic carpeting and if need be cut around where you need to cut. If you order one with a manual opening then you might be stuck with a hole in the wrong spot. Also is it possible to go and ask the original owner?
brokestudent is offline   Reply With Quote
Old 01-08-2014, 06:29 PM   #3
KJSR
KJSR's Avatar
If you have the high hump order it for a 4 speed manual.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 01-08-2014, 06:44 PM   #4
tincan1966
tincan1966's Avatar
4 Speed trucks are the "high hump" and are removable.
Automatics(original) and 3 speeds are normally "low hump" and not bolted in.
When these items are referenced for ordering parts, the part house needs to know the original configuration of the truck not what it is now.
tincan1966 is offline   Reply With Quote
Old 01-08-2014, 07:14 PM   #5
Daking19
cool thanks guys
