Old 01-13-2014, 05:23 PM   #1
forestb
forestb's Avatar
2 headlights to 4
I found a 4 headlight grill at the wreaking yard yesterday and was wondering how do I wire it to work with a truck that originally came with 2. Both have the original wiring harness.
forestb is offline   Reply With Quote
Old 01-13-2014, 06:06 PM   #2
Mackie
Mackie's Avatar
Re: 2 headlights to 4
If all the wiring is orig. now would be a great time to upgrade the system with new heavy gauge wire, sockets and relays.
Mackie is offline   Reply With Quote
Old 01-13-2014, 06:33 PM   #3
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
If you already have the wiring harness with the correct plugs, it is a simple splice, they will share the same ground, so just use a test light, (or a wiring diagram) and split off the hi/lo +12v. But as mentioned above, this is a great time for new wiring, new sockets (most parts stores should have the correct ones) and relays. Also make sure you have an adequate ground. You will likely see increased output from this.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 01-13-2014, 10:42 PM   #4
Vernski
Here is a link to a thread about quad lights...Vernski
http://67-72chevytrucks.com/vboard/s...d.php?t=362778
Vernski is offline   Reply With Quote
Old 01-13-2014, 11:56 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I agree it's a great time to upgrade the wiring and add relays, but if your current wiring is stock and you want to go from 2 headlights to 4, simply unplug the connector just to the drivers side of the radiator and plug in the new grille harness. Everything from the radiator bulkhead back is the same. The only difference between the 2 and 4 headlight wiring is in the grille/headlight harness itself. Same thing works in reverse, going from 4 headlights to 2.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-14-2014, 11:02 AM   #6
jchav62
1962 C-10
jchav62's Avatar
I went from 4 to 2 a while back and it was just plug and play...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
