Old 01-13-2014, 06:00 PM   #1
wayno
Tool for alternator nut
Going to run a serpentine belt - there's gotta be a told made for tightening this nut - does anyone know what it's called and where I can find one? thanks in advance.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 01-13-2014, 06:18 PM   #2
Snailed
Snailed's Avatar
Re: Tool for alternator nut
A dab of loctite, a leather glove and an impact gun? I assume that's how GM does it...
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 01-13-2014, 08:00 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Agree. An impact will do it no problem. Just hold the pulley with a gloved hand.
Old 01-13-2014, 08:25 PM   #4
Mike Wessinger
Mike Wessinger's Avatar
Another vote for impact gun. Removed a pulley from my old alternator with a cheap impact just yesterday afternoon. Wearing a leather glove with a tight grip on the fan, and I was surprised at how easily it broke it loose and spun it right off.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab
Mike Wessinger is offline   Reply With Quote
Old 01-13-2014, 09:54 PM   #5
wayno
Thanks guys... impact gun it is. Much appreciated.
Old 01-13-2014, 09:59 PM   #6
wayno
On other notes - can someone tell me if there is washer beneath the nut that holds on the power steering pump pulley - I have the nut here but was expecting a washer...
Old 01-14-2014, 12:01 AM   #7
Wrenchbender Ret
Yes. There is a washer that goes behind the nut. It is a narrow lock washer.
I agree an air impact is the way to handle the nut. If you do not have one you can use a box wrench & hold the armature with an allen wrench in the shaft.
Wrenchbender Ret is offline   Reply With Quote
Old 01-15-2014, 10:28 AM   #8
wayno
64 stepside - it's a 327 SBC - it's just running a mid serpentine belt setup and thus all the replacing of pulley's and what's required as far as nuts and washers etc.
-W
