Old 01-14-2014, 10:27 AM   #1
1adam12
1adam12's Avatar
What size rims and you running on 2wd lowered blazers
Trying to figure out what size rims and tires i want to run on my 73 2wd blazer lowered with spindles and flip kit..Let me know what you guys are running.New to these years not sure what i shoild go with..
1adam12 is offline   Reply With Quote
Old 01-14-2014, 06:00 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: What size rims and you running on 2wd lowered blazers
Probably the best info is in the 2wd Blazer and Burb picture sticky thread above, where you can find the look you like and see what they are running. What diameter rim do you want to run?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-16-2014, 09:09 PM   #3
kevinr1970
I am running 275/60-15, 235/70-15 but have not lowered it yet. Don't think it will be a problem though?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-17-2014, 10:53 PM   #4
tobiahr
tobiahr's Avatar
I had to move up to 17 inch rims to get the drop spindles to clear on mine. Running 275/55r17 on 17x8 Coy c5's. See some pics at
http://67-72chevytrucks.com/vboard/s...1&postcount=10
tobiahr is offline   Reply With Quote
Old 01-19-2014, 07:31 AM   #5
BaggedRanger
BaggedRanger's Avatar
20" with 255/35 and 275/40 I can turn lock to lock the only time it would rub would be if I was all the way to one side and backing up. Going forward no issues..
BaggedRanger is offline   Reply With Quote
Old 01-19-2014, 07:38 PM   #6
bdiamond
That looks awesome. Do you have specs on the wheels
bdiamond is offline   Reply With Quote
Old 01-20-2014, 12:15 AM   #7
BaggedRanger
Truck came with them so I don't have the backspacing but they are 20x8.5 and 20x9.5 AE Torque Thrust II's..
Old 01-24-2014, 03:48 AM   #8
american revolution
american revolution's Avatar
22's rear 295/40/22.....20's front 255/40/20
If I were to redo I would get 22's all around
american revolution is offline   Reply With Quote
Old 01-24-2014, 06:23 AM   #9
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I've just bought a set of Boss 338 20 x 10 and 20 x 8 for my 71 2wd. Ill post pics as soon as I get tires and installed. Truck has drop spindles and 5" rear springs
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
