Old 01-14-2014, 10:01 PM   #1
of13swc
door hinge bolt plates?
Is there anywhere that sells the plates the go inside the pillars that hold the door hinges? Really need a set. the ones I have been taped way to much and the bolt size I would have to go up to is way to large.
of13swc is offline   Reply With Quote
Old 01-15-2014, 01:42 AM   #2
Captainfab
60-66 Nut
Re: door hinge bolt plates?
Do you need all 4?
Old 01-15-2014, 01:42 AM   #3
Cape Codder
Cape Codder's Avatar
get a piece of 1/4" plate drill tap install
Cape Codder is offline   Reply With Quote
Old 01-15-2014, 06:46 AM   #4
oldtrux
oldtrux's Avatar
Trique mfg. has them in stainless
oldtrux is offline   Reply With Quote
Old 01-15-2014, 06:53 AM   #5
dodgiesdad
dodgiesdad's Avatar
Use a threaded insert such as a Recoil, E-Z LOK, or a Heli-Coil. With these you would drill the hole out larger, tap it and install a insert back to the original thread size.
dodgiesdad is offline   Reply With Quote
Old 01-15-2014, 07:26 AM   #6
of13swc
No I just need 2
Old 01-15-2014, 08:42 AM   #7
of13swc
I only need 2
Old 01-16-2014, 01:28 AM   #8
Captainfab
60-66 Nut
I probably have 2 good ones, I'll look and see.
Old 01-16-2014, 08:12 AM   #9
of13swc
Captianfab you would be a life saver. I really don't want to make these things.
Old 01-16-2014, 08:32 AM   #10
tincan1966
tincan1966's Avatar
I've had to make several over the years, really not that bad to do. Hardest part is getting them back in if the "cage" part is gone in the door post.
tincan1966 is offline   Reply With Quote
