Newbie starting a 65
I have gone thru the rearend replaced every thing but the housing, same on front all new, sand blasted frame , put a mild SBC 350/700r4, split the brake lines and I have a booster from a 87 Chevy 1/2 ton bolted to the firewall , which master cyl. do I need to buy and do I need one of those proportioning blocks? It's all drum/drum stock. All info is welcome
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Newbie starting a 65
With that booster you will want to use a master cylinder for a '70 Buick Estate wagon. It is A1 Cardone #10-1363. With a drum/drum system you do not have to use a proportioning valve. The factory applications had a sort of metering block which housed the brake warning switch.
Thank you so much for the info
![]() We Like Pics… Hint, Hint ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
Post Whore
![]() Join Date: Mar 2013
WELCOME!!!!!!
X2 on the pictures!!!!!! ![]()
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I will try to post some pics this weekend
I found a couple of pics
