01-19-2014, 08:45 PM | #1 |
Which sway bars f/r? No junk yard purchases.
I have a 70 with stock control arms in front and trailing arms.
I have drop spindles being put in now along with drop coil springs for about a 4.5 drop front. I will be changing over to bags in the front within 6 months hopefully. The rear is currently bagged on trailing arms. I already have but need to install a porterbuilt stage 1 rear bag kit to replace the op's pieced together bag setup that is there now along with a porterbuilt adj. track bar. I want to add sway bars front and rear as I have neither currently. I have read a number of threads and most recommend going to a stock HD bar but I do not have the time or inclination to search junk yards for the right combo for both front and rear. I just want to spend the money and buy something that works with the suspension I have now and in the case of the front, will be going to in the future. Can someone give some recommendations?
1970 Shortbed 2wd C-10 |
01-21-2014, 01:56 PM | #2 |
Happy to be here
Re: Which sway bars f/r? No junk yard purchases.
Try looking in the Forum Marketplace. There should be more than one Vendor that has what you need.
01-21-2014, 02:15 PM | #3 |
Addco or Hotchkis make decent bars for these trucks. Like suggested, contact one of the vendors here to see what product lines are available. You could also try Summit Racing to see what alternatives there are.
