Old 01-20-2014, 05:01 PM   #1
grs
Carburetor ????
What is a square bore, and a spread bore carb. What is the diff?
grs is offline   Reply With Quote
Old 01-20-2014, 06:22 PM   #2
66Submarine
66Submarine's Avatar
Re: Carburetor ????
Square bore means the primary and secondary circuit is symmetrical. Spread bore means that the primary circuit is smaller than the secondary. For example; a regular 750 Holley is a common square bore carb, and a Rochester Quadrajet is a common spread bore.
The idea with a spread bore carb is that when you are just normally driving with the primary circuit it acts like a smaller carb. The airflow/vacuum signal is stronger/faster, and that (in theory, anyway) makes it more efficient/precise. But unlike a smaller carb, you still have the larger secondary circuit when you stand on it.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 01-20-2014, 11:01 PM   #3
grs
Re: Carburetor ????
Well I learned something today. I guess you can learn an old hillbilly new tricks.
Old 01-21-2014, 07:24 AM   #4
tincan1966
tincan1966's Avatar
Re: Carburetor ????
THAT was one of the best explanations, I have ever seen to describe the differences!
tincan1966 is offline   Reply With Quote
