Old 01-21-2014, 09:26 PM   #1
Bagged1972
I know this isn't a C10 and off topic
well here it is I ran across this 65 Divco milk truck and I was trying to figure out what to do with it cause I don't won't to send it to the crusher and I'm a true believer of everything can be fixed but anyway does anyone know if I can take the body off and sit on a 67-72 C10 frame thanks guys for the help
Bagged1972 is offline   Reply With Quote
Old 01-21-2014, 09:47 PM   #2
flashed
Re: I know this isn't a C10 and off topic
WOW ,that thing is sooo cool.
flashed is offline   Reply With Quote
Old 01-21-2014, 10:08 PM   #3
Pro Performance
Pro Performance's Avatar
I like it! Would look sweet on a set of Diesel Wheels and laying on the ground. I don't have any information on fitting on a 67-72 frame, but sure anything is possible. I would check into the wheel base difference between the two frames, and go from there.
Pro Performance is offline   Reply With Quote
Old 01-21-2014, 10:45 PM   #4
Bagged1972
Thanks guys it will be sweet once it's finished it's gonna be a long road ahead but the good thing is just about everything on it that's rusted is flat and unbolts so maybe it won't be to bad. But anyway I own a 72 C10 and the wheel base is the exact same as the milk truck
Old 01-22-2014, 07:37 PM   #5
LONGHAIR
That is awesome, I have wanted to build a Divco truck for years.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-23-2014, 07:21 PM   #6
midniteblues
midniteblues's Avatar
that will make a cool ride one day.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-23-2014, 07:43 PM   #7
Bagged1972
It's a long road ahead
Old 01-23-2014, 10:03 PM   #8
team39763
I would love to have something like that to use as a mobile tool box/shop truck.
Check this ad out.
http://sanantonio.craigslist.org/cto/4279168663.html
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 01-24-2014, 06:33 PM   #9
RaceAGMC
RaceAGMC's Avatar
Where did you find that gem?
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 01-24-2014, 06:53 PM   #10
Bagged1972
Buried deep in the woods in North Carolina they guy I got it from drove it in the early 80's the he parked it in the woods and never looked back
Old 01-24-2014, 10:12 PM   #11
kamikazekyle05
kamikazekyle05's Avatar
That thing is sweet!!!
kamikazekyle05 is offline   Reply With Quote
Old 01-25-2014, 11:56 AM   #12
3drburb
Thats a very nice truck you have.
I think you are on the right track with the frame, but keep in mind that the Divco have the steps into the van and the newer frame may be a little wider if so you will need to alter the floor but that may be needed to add seats anyway. If you find a 3/4 or 1 ton truck frame it should work better because the weight of the truck. You can also consider putting the newer crossmember and rearend on the old frame, this maybe be the best way to do it if the old frame is still solid.
I am considering this on my 1946 Chevy Package Delivery with the 127 wheelbase also.
Be extra carefull with this one its a very top heavy truck.
3drburb is offline   Reply With Quote
