ECE rear shocks
I did a search, but can't seem to find the right combination.
I dropped the rear of my 70 with the ECE 4/6 kit and the only way the shocks worked were to place them "upside down". Meaning the larger cup end was at the bottom...they appear to work fine, but I'm a little concerned with water getting into the larger cup and sitting there, and causing rust issues and potential shock failure. Do I have them incorrectly installed? |
Java Mechanic
Re: ECE rear shocks
I don't think they should go upside down. We'll see what others say.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: ECE rear shocks
I've done at lot of ECE installs. Never had to install the shocks upside down. I think your concern about holding water is very valid.
If you can post a picture of what you have, we can see what's wrong and help you figure it out.
Re: ECE rear shocks
I have always installed them upside down I guess. I didn't realise that the larger cup end was designed to go at the top.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
