01-28-2014, 04:01 PM | #1 |
1965 long bed to short bed...opinions please!
Hi,
I need opinions on converting my recently purchased 1965 Custom cab, BBW long bed to a short bed. I watched "all" the video's (Youtube and truck shows on TV and online archives) also read the Googled articles on this conversion. I have the tools and shop to do the work. No time restraints. Has anyone done it that has input? Would they do it again? Any and all info is greatly appreciated. Thanks in advance, Dan |
01-28-2014, 05:03 PM | #2 |
Re: 1965 long bed to short bed...opinions please!
I Love long beds... Don't do it Dan, don't cut that cool truck in half! FWIW
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
01-28-2014, 05:07 PM | #3 |
From what I understand, the rear wheel openings are different on long beds compared to short-beds.
A spirit with a vision is a dream with a mission - Neil Peart RUSH |
01-28-2014, 05:21 PM | #4 |
What are your plans for lowering it?
If they sit high I like them better as long beds and lowered better as short beds.
65 C20 292 4spd 4:56 Eaton HO52 |
01-28-2014, 05:33 PM | #5 |
just cut it worse case scenario you find a swb frame and bed and swap all your parts over. personally I don't see any point in spending any money fixing up a lwb when you really want a swb.
70 SWB STEPSIDE 70 BLAZER 09 challenger |
01-28-2014, 05:45 PM | #6 | |
Anyone...I'm I correct? Thanks again, Dan |
01-28-2014, 06:16 PM | #7 |
I have done it...on 2 trucks. Yes I would do it again. why would I do it again?. Because the first one I have never had done it before. The second one, I did to help a friend do his. Now we both are not intimidated to try new things. Plus, it just plan looks cool with those big Ass wheel openings.
Get out your torch and start cutting. if you make a mistake there's thousands more long beds out there to fix it. When your done you can stand back and feel pround you did it yourself...
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-28-2014, 06:21 PM | #8 | |
01-28-2014, 06:22 PM | #9 | |
01-28-2014, 07:43 PM | #10 |
I shortened the one in my build thread, I would do it again for a non original type truck, but I would not for a stock type resto. And yes the wheel arches are appr.3" wider at the bottom than a normal short bed.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
02-02-2014, 06:38 PM | #11 |
does anyone know if the 12"/8" cut still works on longbed steps? Are the fender wheel openings the same on lwbss and swbss rear fenders? I want to do perform this surgery on my long step this summer. On the lwbss the wheel sits back in the opening and on the swbss its more centered. I just want to make sure that after doing the 12/8 cut that swb trailing arms put the wheels in the right spot.
02-02-2014, 06:49 PM | #12 |
Your truck- your decision.
02-02-2014, 09:04 PM | #13 |
Go buy a frame and bed and sell the ones your not using... I'd restore the truck as is. How about some more pics of the truck?
02-02-2014, 09:27 PM | #14 |
You can always shorten the frame, and use new swb bedsides.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
02-02-2014, 10:03 PM | #15 |
Hey I'm in the process of doing one right now and I would do it again something are little tough to figure out but it's worth it and I would do it again no problem.
02-03-2014, 12:58 AM | #16 |
But Found Her 25yrs Later!
I'll be doing a medium bed. A 7 footer.
To me; 6 ft is too short and 8 ft is too long. There's a thread in these forums with pics.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
02-03-2014, 03:25 AM | #17 |
Here on gears stacy cut a long bed down to a short bed
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
02-03-2014, 03:26 AM | #18 |
Here is another one
02-03-2014, 08:42 AM | #19 |
Long and low is the only way to go.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
02-03-2014, 08:58 AM | #20 |
Bottom line is it's your truck and you should be able to have what you want...some guys are short bed guys and some are not...that being said...if you start to shorten it do not stop until you finish it..all to often I see people start conversion or something drastic on a project and it end up on Craigslist in a heap nobody would own.....if you start it just finish it otherwise leave it alone...but I'm like you I prefer short beds unless I'm using it for work, but these truck are my toys...Are you wanting to keep the patina?
02-03-2014, 09:30 AM | #21 |
I say do it. When i get another 60-66 it most likely be a long bed. Just because there are more of them out there. I too will convert it to a short bed. If you have the time and know how do it. It's your truck so do what you feel! Good luck!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
02-03-2014, 09:41 AM | #22 |
I wish you were closer. I would trade you a short bed for that long bed. I have an extra and just picked up a 3/4t and it needs a bed. you can shorten them but it is pretty hard to make them longer...
02-08-2014, 10:38 PM | #23 |
I think I like the medium bed look also.
Does a true factory short bed measure 6 foot (72 inches) inside the bed from front panel to inside tailgate? thanks, Dan |
02-09-2014, 02:59 AM | #24 |
Pretty sure it's 6'6" from front panel to inside of tailgate. The wood is about 77".
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
02-09-2014, 03:07 AM | #25 |
I shortened my '66 box first thing. Wanted to have the bigger wheel opening to show off my 22's.
I'd do it again. I even have a '72 box waiting for its turn. Go for it! |
