01-29-2014, 11:41 AM | #1 |
965 gmc long bed wood
we need to replace the wood in the bed. does anyone have the wood sizes? we have replaced wood before in other trucks but always cut the wood. the wood is so bad that i can't even measure it. thanks for your help.
01-29-2014, 12:14 PM | #2 |
Re: 965 gmc long bed wood
Check the Mar-K web page, I think they are there.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
01-29-2014, 12:19 PM | #3 |
I found it for you.
http://www.mar-k.com/Catalog/PDF/Ins...Dimensions.pdf
01-29-2014, 12:40 PM | #4 |
01-29-2014, 03:20 PM | #5 |
Go to a commercial lumber yard and buy your pine wood their, lowes and home depot are 3 times higher. We bought the pine for my 66 for $55.00 then cut it to Mar-K dimensions and it worked like a charm......I did cheat a little, got to pick thru a new load of pine myself and cherry picked the best boards......Kieth
looked like this finished: http://kieth.smugmug.com/Trucks/66-GMC/i-DZW9XDm like this as we installed: http://kieth.smugmug.com/Trucks/66-GMC/i-tLxvc8z like this as we initially processed it and trimmed with table saw, and cut groves with dado blade: http://kieth.smugmug.com/Trucks/66-GMC/i-ngvCcFt we did have to modify the cuts later and make the grove deeper and wider to the outside of the board just to get some wiggle room. laid it out before painting to check fit: http://kieth.smugmug.com/Trucks/66-GMC/i-skgXcKr |
01-29-2014, 03:25 PM | #6 |
Moderator
01-30-2014, 01:17 PM | #7 |
thank you we learned alot.
