Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-04-2014, 12:23 PM   #1
1963c-10
1963c-10's Avatar
FREE 1961 Short bed frame whole/parts
I have a 61 swb frame sitting in the yard. Has complete suspension. Anybody who wants it or any parts off of it can come get them. I will have the frame towed off for scrap in 2 weeks if its not gone by then. Bring tools for whatever you want, although I can help some with tools and labor. If you want the whole frame as it is, its your. Frame is straight, has the HO 52 10 bolt rear (gear unknown), and all front/rear suspension is there. Originally was a fleetside w/6cyl and 3 speed, but could be used with a stepside if desired pretty easily.
I really hate to send it to the scrap yard as the front end components are expensive for the 60-62's, and I'd like to just find a good free home for it, but either way....in two weeks it'll be gone.
Take a little or take a lot, but please come take it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-04-2014, 10:08 PM   #2
kenny_strong
kenny_strong's Avatar
Re: FREE 1961 Short bed frame whole/parts
Any pictures of rear trailing arms?
kenny_strong is offline   Reply With Quote
Old 02-04-2014, 11:13 PM   #3
qksilver
does it roll? I have a truck and trailer and am only around 40 miles away. I need a swb frame for a project but never have dealt with the torsion bar front suspension. I know about the x frame brace but can a later model cross member be installed like a 78 1/2? I have a lot of left over parts and is that rear ten bolt, 1/2 ton 6 lug?
Let me know, I can PM my number and pick it up Friday.
Thanks,
Steve
scjkovach@qaol.com
qksilver is offline   Reply With Quote
Old 02-05-2014, 01:35 AM   #4
62chevy302
hillbilly
62chevy302's Avatar
Interested in frame. Pm with contact info
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 02-05-2014, 10:06 AM   #5
1963c-10
1963c-10's Avatar
The frame has rims and tires on it, but I need the two rear tires/rims as they are off my other project. We can get the frame loaded, but I would need to take off the two rear tires/rims once its loaded. The cab and front end in the picture are not included. I will help with what labor and tools I can. I have a jack and 4 way lug, which is really about all that would be needed. Frame will roll, hasn't been moved in 3 months, but that shouldn't be an issue. I would recommend a come-a-long just as a backup to get it loaded.
easiest contact for me is email due to my work load: emt0289@yahoo.com or PM me here
I can get more pics of the frame, but will take a day or two. I wont be home until after dark tonight. Picked up a 63 bbw short fleet and need the space.
Old 02-05-2014, 02:35 PM   #6
qksilver
sounds good, I use a come along any way to load. Had 2 winches stolen off my trailer. I think have 2 6 lug wheels. Still for me, the main question is will I be able to swap a later model crossmember and suspension to the front? I have heard all sorts of horror stories about the torsion front suspension and my left over suspension parts are for later models.
If I can use a later model bolt one suspension on this frame I will "TAKE IT" and can pick it up Friday.
Email me a number and I can call you.
Thanks,
Steve
quicksilver69@aol.com
Old 02-05-2014, 02:57 PM   #7
1963c-10
1963c-10's Avatar
There is a thread in the FAQ section on using a newer model crossmember on the 60-62 frames. I'll see if I can find the link.
Old 02-05-2014, 03:00 PM   #8
1963c-10
1963c-10's Avatar
check out thread # 2 on this link. Using a 63-87 crossmember on a 60-62 frame
link: http://67-72chevytrucks.com/vboard/s....php?p=4450757
Old 02-05-2014, 03:09 PM   #9
1963c-10
1963c-10's Avatar
Kenny strong was 1st to respond, so he has 1st dibs quicksilver, but if hes not interested its yours. I tried to email you quicksilver at the email you provided and it keeps sending it back to me. I'll pm you my #.
Old 02-05-2014, 05:18 PM   #10
1963c-10
1963c-10's Avatar
2 more pics. I took the rear driver side tire off Sunday due to a bad valve stem. Frame looks good other than surface rust and damage to one frame horn (see top mounting bolt) should be an easy fix.
Old 02-05-2014, 09:41 PM   #11
kenny_strong
If quick silver can get it let him have it. I only need the trailing arm set up so I would rather see him be able to use the whole frame.
Old 02-05-2014, 10:45 PM   #12
qksilver
whoops, my meds must have kicked in! it's qksilver69@aol.com
I am going to check out those threads. It will probably be tomorrow before I call.
I haven't seen one of the frames since the 80's didn't realize the were boxed like that, a bonus! hat looks like a good foundation for a tough 4X4 only have to box toward the front.
Thanks,
Steve
Old 02-05-2014, 10:54 PM   #13
Leroy-B1
If it makes it to me for some reason I really need a frame for my 60 the one I picked up for it was rotten on the back third and I hauled it off for scrap...I'm doing a frame off on a 60 bbw short fleet and need a frame real bad...62chevy302 was actually trying to help me out and was speaking for me he knows my frame issues I'm in Asheville and can make the drive
Leroy-B1 is offline   Reply With Quote
Old 02-05-2014, 11:11 PM   #14
1963c-10
1963c-10's Avatar
if he takes this one, there was a 63 swb frame in nc about 2hrs east of me and i think it was only $200. ill see if i can find the link. unless your specific on a 60-62 frame
Old 02-06-2014, 11:14 AM   #15
Leroy-B1
No mines a 60 want to keep original but thanks
Old 02-06-2014, 11:15 AM   #16
Leroy-B1
I had a powder coated 64 frame I just traded to try and keep correct stuff under it but thanks for that
Old 02-06-2014, 11:50 AM   #17
1963c-10
1963c-10's Avatar
If qksilver doesn't get the frame, its yours. Hes supposed to contact me today.
Old 02-06-2014, 01:49 PM   #18
qksilver
Hey if you really need a 60-62 frame go for it.......I see the 63-66 frames come up once in a while so they aren't that rare. for somebody to really need/want that year frame I will step aside..............63-10 if you have that link for the other frame cool. Email me or
Leroy the frame you have? either way let me know...............
thanks,
Steve
qksilver69@aol.com
Old 02-06-2014, 02:31 PM   #19
1963c-10
1963c-10's Avatar
OK, so Leroy-B1....looks like the frame is yours.
qksilver....i'll find the link on the 63 frame. was I believe 1-2 hours east of Fayetteville. Nice rolling frame w/tires/rims.
Old 02-06-2014, 02:36 PM   #20
1963c-10
1963c-10's Avatar
qksilver....look up member 62 bigwindow, hes in Mocksville nc and had the 63 frame.
Old 02-06-2014, 09:16 PM   #21
qksilver
COOL........i always try to gather all my major stuff before starting my reconstructions. You have jumped me a few times as have I you on craigslist!
Thx,
Steve
Old 02-09-2014, 12:04 AM   #22
bondo510
I am looking for the passenger side frame rail cut a few inches behind the cross member for a 60 thanks
bondo510 is offline   Reply With Quote
Old 02-09-2014, 04:57 PM   #23
Leroy-B1
I found one locally I will pass on this sorry just cant justify a 5 hour drive when I found one here
Old 02-09-2014, 09:38 PM   #24
qksilver
Should have gotten that frame instead of being nice. Just spent $200 and $80 in gas.
Thanks.......................
Steve
Old 02-10-2014, 11:09 AM   #25
1963c-10
1963c-10's Avatar
ok, frames back up for grabs. Will go to the scrap yard next Monday if no one lays claim to it before that.
