Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 02-07-2014, 11:37 PM   #1
Dano69c10
Dano69c10's Avatar
Resetting the oil life % dash warning.
Can anyone tell me the proper way to reset the oil life warning on the dash after an oil change?
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-07-2014, 11:45 PM   #2
imjeff
imjeff's Avatar
Re: Resetting the oil life % dash warning.
Turn the ignition on (engine off), pump the accelerator three times within five seconds of turning the ignition on, then turn the ignition off. I don't know what vehicle you're talking about, but this works on a lot of the newer gm products.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 02-08-2014, 01:42 AM   #3
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
That's the ticket, key on engine off pump 3 times. Vehicles with the upgraded DICs can go through the steering wheel buttons too but they all work with the gas peddle. Turn it off when you're done and it will ding and flash a message that you're good to go and back to 100%.
Tropical Snowstorm is offline   Reply With Quote
Old 02-08-2014, 08:54 AM   #4
GMCJOE
GMCJOE's Avatar
If you have the DIC, you can reset it thru there. If not, the key method will be what you need to do.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 02-09-2014, 12:28 PM   #5
Dano69c10
Dano69c10's Avatar
Sorry, it's a 07 Silverado Worktruck Crewcab,
Thanx for the replies
Dao
'69 Fleet
Old 02-09-2014, 05:23 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Once again if you have a DIC, then select the oil life and push the reset check mark button. The old turn the key on, but do not start, then push the gas pedal three times and whisper please reset my oil as you do it works well. There is a little mic in the dash that can hear your whispers.
Frank
piecesparts is offline   Reply With Quote
Old 02-12-2014, 09:31 AM   #7
Woogeroo
Talking Re: Resetting the oil life % dash warning.
yeesh... and I thought old trucks were aggravating.
-W
Woogeroo is offline   Reply With Quote
Old 02-12-2014, 10:16 AM   #8
Dano69c10
Dano69c10's Avatar
No DIC, but I'll try the pedal method...
'69 Fleet
Old 02-12-2014, 04:11 PM   #9
95 S_Trucker
95 S_Trucker's Avatar
Since it's a work truck, you can also use the trip/reset button, on the upper right part of the cluster.
Press it until you see oil life on the display, Then press and hold to reset it.
95 S_Trucker is offline   Reply With Quote
Old 02-13-2014, 12:02 PM   #10
truckdude239
truckdude239's Avatar
key on engien off press gas pedal 3 times fully to the floor within 5 second but dont pump to fast as it just mess up but you have to wisper please reset my oil light really low
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
