Old 02-16-2014, 05:33 PM   #1
Roll'nSlo
Roll'nSlo's Avatar
Hydraulic clutch
I'm putting a BBC in my '63, I've read that to keep a standard tranny and use headers you have to use a hydraulic clutch. Is this true and anyone that has a way of doing this please let me know. I've never dealt with installing a hydraulic clutch before.
Roll'nSlo is offline   Reply With Quote
Old 02-17-2014, 12:43 AM   #2
Blue666
Re: Hydraulic clutch
Help us out a bit.
What type trans & bell housing are you running?
Blue666 is offline   Reply With Quote
Old 02-17-2014, 12:46 AM   #3
Roll'nSlo
Roll'nSlo's Avatar
Muncie rock crusher. Same bell housing that came on the I6
Old 02-17-2014, 12:47 AM   #4
Roll'nSlo
Roll'nSlo's Avatar
My mistake bell housing is an aluminum housing I got with the 454
Old 02-17-2014, 02:24 AM   #5
Captainfab
60-66 Nut
When installing a big block and a manual trans, converting to a hydraulic clutch is so much easier than modifying and fabricating new mechanical linkage. I do make a brake booster/hydraulic clutch conversion for the '63-'66 trucks. It is basically the same as the brake booster/hydraulic clutch assembly that I make for the '60-'62's. There is a link to the for sale thread in my signature line \/ \/ \/
I do not currently have a bracket to mount the slave cylinder, but I am working on it as time permits. You could use a factory '84-'91 bellhousing or use the Novak slave cylinder and bracket.
Old 02-17-2014, 02:57 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I've had the Novak slave setup in place for 9 years on my 1960 GMC SBC 4 speed. They have changed the design a bit since then but mine continues to work perfectly. The setup can be seen on page 2 of my build thread.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-17-2014, 09:43 AM   #7
Blue666
Jegs, Summit, Novak & many other vendors all carry internal slave/release bearings for your Muncie.
(http://www.jegs.com/p/RAM-Clutches/R...95647/10002/-1)
As Captain Fab described, you need a master cylinder properly fastened to the firewall to actuate the internal slave/internal release bearing. Quality, durable flex lines are also needed.
Good luck, please add some pictures as you build.
Old 02-17-2014, 04:59 PM   #8
Roll'nSlo
Roll'nSlo's Avatar
At the moment I am getting all the necessary parts gathered up. I'm working on getting the truck back on the road to drive for a month or two and then tearing it down and do a frame off resto on it. I've learned so much from everyone on this forum. Unlike the other one I joined(not helpful at all). But I promise I'll start a build sheet when I get started on it. I'm the type that wants everything laid out in my head of what I want and how to do it before I start. Naturally half way thru it I'll changed something I'm sure.
Mark I've read your build before. I just forgot about the clutch section partially because I was going to go with a TH400 at that time. Thanks for bringing it to my attention again. I'm going to use the same setup for mine. Hoping I can get the bracket from Capt.
Capt I sent you a pm. Hopefully with your bracket and a lil guidance(if needed) it'll go together without any problems.
Old 02-17-2014, 05:08 PM   #9
1963c-10
1963c-10's Avatar
I just did a novak conversion, but have not installed it in the truck yet. Its all mocked up and ready to install. Its a very nice kit and the design has changed a little from Markeb01's version. Theres some pics of it on my build.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
