Old 02-16-2014, 10:13 PM   #1
kdog3121
5 window conversion
Has anyone seen a 47-54 5 window modified to make a one piece rear window wrap around window... like a big back window from the 55-59???
Obviously it would require custom glass but I've been thinking of doing this to the next project.
kdog3121 is offline   Reply With Quote
Old 02-16-2014, 11:36 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 5 window conversion
I have never seen it done but it would look awesome!
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-16-2014, 11:40 PM   #3
BlueJeep
BlueJeep's Avatar
I'd check into the ability to build the window and price of it before going too far with that project! I've seen a 3 window with a larger window in the back, but that's just flat glass so it would only be a matter of building the opening as big as you want it.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-17-2014, 07:18 PM   #4
low54panel
That would look neat, would look into the glass before cutting anything though
low54panel is offline   Reply With Quote
Old 02-17-2014, 07:26 PM   #5
ghettoluxury
I know there are companies that can replicate glass from an aluminum panel.
Old 02-19-2014, 02:24 PM   #6
wickid demon
wickid demon's Avatar
If you make a buck and send it to AM hot rod glass they can make you the rear window out of acrylic. You can’t tell the differences between real and the acrylic it is a great product. Go for it. O... the price for the rear window should be around $600. Not bad for an awesome look.
Ryan
My Wickid 54 http://67-72chevytrucks.com/vboard/s...d.php?t=518657
wickid demon is offline   Reply With Quote
Old 02-19-2014, 06:32 PM   #7
ghettoluxury
Here are a couple crude drafts of what this would look like.
Old 02-19-2014, 08:27 PM   #8
wickid demon
This needs to be done. I might consider it. But that is a lot more work to my already over worked truck.
Ryan
Old 02-23-2014, 04:06 PM   #9
53 292
53 292's Avatar
Check out post #311 about halfway down the page
http://www.jalopyjournal.com/forum/s...+chevy&page=16
53 292 is offline   Reply With Quote
Old 02-23-2014, 08:11 PM   #10
53 292
53 292's Avatar
Figured out how to post it
