02-17-2014, 09:54 AM | #1 |
Stupid Belt Noise
I've got a 1962 235, and the belt noise is driving me nuts.
The Crank pulley looks a little wider than the water pump and alternator pulleys. (the belt is farther "down" into the crank pulley) I can squirt a little belt dressing on and it gets silent (heaven!), but only for a minute. The alignment looks right, and the belt is tight. Is there an easy fix? |
02-17-2014, 11:46 AM | #2 |
Re: Stupid Belt Noise
I have used a old trick of rubbing bar soap on the belt .
02-17-2014, 12:02 PM | #3 |
Post Whore
I had the issue slightly when I had the 40+ year old belt still on....I got one of Napa's premium belts and even on cold mornings nothing squeaks. My pullleys are a little narrower I think.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-17-2014, 01:44 PM | #4 |
I put a new, premium belt on - helped, but not 100%
I'll try the soap - thanks Jim. |
02-17-2014, 02:53 PM | #5 |
Belt noise can also be caused by the pulleys being worn out. The belt will actually slip as it goes around the pulley no matter how tight the belt is.
02-17-2014, 04:22 PM | #6 |
Senior Enthusiast
It is likely the pulleys are not compatible. I no longer remember the angles, but the really wide original pulleys may have required a 40 or 45 degree side angle on the belt. I think the newer (thin) belts were pretty standard at 37 degrees (or something close to that). The only permanent cure may be replacing that lower pulley with one that matches the water pump and alternator.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-17-2014, 04:23 PM | #7 |
Same here....I've learned to love it...sounds like a gear drive cam shaft....increasing in pitch with rpm till eventually it blends in with the sound of a cinderblock wall being pushed thru a hurricane at 70 mph!
Check pully alignment....I tweaked my alternator position with shims and thinning of the bracket tab and eliminated a buncha that whine. |
02-17-2014, 07:45 PM | #8 |
Who Me?
Make sure all the pulleys are lined up too.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-17-2014, 10:02 PM | #9 |
Take the "Shine" out of the pulley with sandpaper or the like. Stop using belt dressing it just makes it slip more.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-18-2014, 08:58 AM | #10 |
Thanks for all the advice!
